HP HP 305 2-PACK TRI-COLOR/BLACK
Quicklinx: HCTDWS00 Mfr#: 6ZD17AE
Print high-quality documents with Original HP ink cartridges – designed with the printer for excellent worry-free performance.
  • Designed to work the first time, every time
    Be assured that HP Original Cartridges will consistently deliver quality results and premium performance.
  • Quality prints you can take pride in
    Experience premium print quality with HP Original Cartridges designed for vibrant colour, crisp text, and rich blacks for big impact.
  • The environmental choice
    Print with confidence – HP Original Cartridges designed with the planet in mind for easy recycling and less waste.
  • Better together. Better results
    HP Original Cartridges are the only cartridges precisely developed with HP printers for reliable quality, results, and consistent performance.
  • Get the most from your ink
    Get the most from your HP printer – and your ink. Print the high-quality documents and store-quality photos you need, using HP Original Ink Cartridges. Choose between cartridge sizes to match your printing volume and budget.
  • Crisp, sharp text and vivid colours
    Make a good impression with HP Original Ink Cartridges – designed to deliver vivid colour and crisp, sharp text.
HP 305 - 2-pack - black, colour (cyan, magenta, yellow) - original - ink cartridge
Ink cartridge
Printing Technology
Ink-jet
Printing Colour
Black, colour (cyan, magenta, yellow)
Yield
Up to 120 pages (black) , Up to 100 pages (yellow/cyan/magenta)
Included Qty
2-pack
Compatible with
Deskjet 1200, 23XX, 27XX, 28XX, 41XX, 42XX; DeskJet Plus 41XX; ENVY 60XX, 64XX; ENVY Pro 64XX
Dimensions (WxDxH) / Weight
89 g
Shipping Width
10.9 cm
Shipping Depth
3.85 cm
Shipping Height
12.5 cm
Shipping Weight
90 g
Consumable
Consumable Type
Ink cartridge
Printing Technology
Ink-jet
Included Qty
2-pack
Consumables Included
1 x ink cartridge (black) - up to 120 pages , 1 x ink cartridge (yellow/cyan/magenta) - up to 100 pages
Compatible with
HP Deskjet 1200c, 1200c/ps, 1200ps, 2320, 2330, 2331, 2332, 2710, 2710e, 2720, 2720e, 2721, 2721e, 2722, 2722e, 2723, 2723e, 2724, 2725, 2729, 2732, 2734e, 2742, 2742e, 2752, 2752e, 2755, 2755e, 2776, 2810e, 2820e, 2821e, 2822e, 2823e, 2855e, 4110e, 4120e, 4121e, 4130e, 4132e, 4152e, 4155e, 4158e, 4175e, 4210e, 4220e, 4222e, 4230e, 4255e , HP DeskJet Plus 4110, 4120, 4121, 4122, 4122e, 4123, 4130, 4140, 4152, 4155, 4155e, 4158 , HP ENVY 6010, 6010e, 6020, 6020e, 6022, 6022e, 6030, 6030e, 6032, 6032e, 6034, 6034e, 6052, 6052e, 6055, 6055e, 6058, 6075, 6420e, 6430e, 6432e, 6452e, 6455e, 6458e , HP ENVY Pro 6420, 6422, 6430, 6430e, 6432, 6432e, 6452, 6454, 6455, 6455e, 6458, 6475
