HP HP 305 2-PACK TRI-COLOR/BLACK
Quicklinx: HCTDWS00 Mfr#: 6ZD17AE
Type: Ink Cartridge
Technology: Ink-Jet
Sorry but this product has been discontinued.
View used stock
Print high-quality documents with Original HP ink cartridges – designed with the printer for excellent worry-free performance.
  • Designed to work the first time, every time
    Be assured that HP Original Cartridges will consistently deliver quality results and premium performance.
  • Quality prints you can take pride in
    Experience premium print quality with HP Original Cartridges designed for vibrant colour, crisp text, and rich blacks for big impact.
  • The environmental choice
    Print with confidence – HP Original Cartridges designed with the planet in mind for easy recycling and less waste.
  • Better together. Better results
    HP Original Cartridges are the only cartridges precisely developed with HP printers for reliable quality, results, and consistent performance.
  • Get the most from your ink
    Get the most from your HP printer – and your ink. Print the high-quality documents and store-quality photos you need, using HP Original Ink Cartridges. Choose between cartridge sizes to match your printing volume and budget.
  • Crisp, sharp text and vivid colours
    Make a good impression with HP Original Ink Cartridges – designed to deliver vivid colour and crisp, sharp text.
HP 305 - 2-pack - black, colour (cyan, magenta, yellow) - original - ink cartridge
Ink cartridge
Printing Technology
Ink-jet
Printing Colour
Black, colour (cyan, magenta, yellow)
Yield
Up to 120 pages (black) , Up to 100 pages (yellow/cyan/magenta)
Included Qty
2-pack
Compatible with
Deskjet 1200, 23XX, 27XX, 28XX, 41XX, 42XX; DeskJet Plus 41XX; ENVY 60XX, 64XX; ENVY Pro 64XX
Dimensions (WxDxH) / Weight
89 g
Shipping Width
10.9 cm
Shipping Depth
3.85 cm
Shipping Height
12.5 cm
Shipping Weight
90 g
Consumable
Consumable Type
Ink cartridge
Printing Technology
Ink-jet
Included Qty
2-pack
Consumables Included
1 x ink cartridge (black) - up to 120 pages , 1 x ink cartridge (yellow/cyan/magenta) - up to 100 pages
Compatible with
HP Deskjet 1200c, 1200c/ps, 1200ps, 2320, 2330, 2331, 2332, 2710, 2710e, 2720, 2720e, 2721, 2721e, 2722, 2722e, 2723, 2723e, 2724, 2725, 2729, 2732, 2734e, 2742, 2742e, 2752, 2752e, 2755, 2755e, 2776, 2810e, 2820e, 2821e, 2822e, 2823e, 2855e, 4110e, 4120e, 4121e, 4130e, 4132e, 4152e, 4155e, 4158e, 4175e, 4210e, 4220e, 4222e, 4230e, 4255e , HP DeskJet Plus 4110, 4120, 4121, 4122, 4122e, 4123, 4130, 4140, 4152, 4155, 4155e, 4158 , HP ENVY 6010, 6010e, 6020, 6020e, 6022, 6022e, 6030, 6030e, 6032, 6032e, 6034, 6034e, 6052, 6052e, 6055, 6055e, 6058, 6075, 6420e, 6430e, 6432e, 6452e, 6455e, 6458e , HP ENVY Pro 6420, 6422, 6430, 6430e, 6432, 6432e, 6452, 6454, 6455, 6455e, 6458, 6475
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: HCTD 051376
Condition: Damaged stock - Item is new but has packaging damage
This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is not present or functional  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  £11.67
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Type: Ink Cartridge
Technology: Ink-Jet
Brand: HP
Stock Status: Used Stock
Stock Status: Clearance
