Deploy a display optimized for patient rooms, nurses stations, medical carts, and public areas with the HP Healthcare Edition HC241. It is built for easy, repeatable sanitization after every patient engagement and is DICOM Part 14 compliant for accurate viewing of medical images.
Promote patient safety
Be ready for the next patient or user with a display and optional stand that are sanitizable with germicidal wipes. The display is IEC 60601-1-2: 2014 compliant for use near patients and staff and the front is IP 32 rated against water ingress. -
Out-of-the box image accuracy
Help ensure accurate, consistent image viewing between healthcare professionals and for patient consultations and image verification with a DICOM Part 14 compliant display. See more and scroll less on the WUXGA 24-inch diagonal screen. -
Create an efficient workspace for high-traffic areas
Attach select HP PCs behind the display for a compact, integrated solution that's perfect for busy and shared spaces like nurses or charting stations. Mount on a medical cart, wall or arm with the VESA pattern.
- HP HC241 Clinical Review Monitor - Healthcare - LED monitor - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class F
- Energy Consumption per Year
- 33 kWh
- Power Consumption (On mode)
- 22 W
- USB 3.0 hub
- Panel Type
- AHVA
- Aspect Ratio
- 16:10
- Native Resolution
- WUXGA 1920 x 1200 at 60 Hz
- Pixel Pitch
- 0.27 mm
- Brightness
- 270 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 14 ms (grey-to-grey)
- Input Connectors
- HDMI, VGA, DisplayPort
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- White
- 56.36 cm x 19.7 cm x 55.16 cm
- 6.87 kg
- Localisation
- English / United Kingdom
- Plug and Play, UL, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, MEPS, CECP, EAC, ISC, low halogen, CE/EMC
- Display Type
- Energy Class
- Class F
- 33 kWh
- Diagonal Size
- 24"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- AHVA
- Aspect Ratio
- 16:10
- Native Resolution
- Pixel Pitch
- 0.27 mm
- Brightness
- 270 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- Vertical Refresh Rate
- 60 Hz
- Horizontal Refresh Rate
- 80 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Mercury free, arsenic free
- White
- 56.36 cm x 19.7 cm x 55.16 cm - with stand
- 6.87 kg
- DisplayPort (HDCP) , HDMI (HDCP) , VGA , 2 x USB 3.0 downstream , USB 3.0 upstream
Mechanical
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), detachable stand, VESA interface support
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- 22 W
- Power Consumption SDR (On mode)
- 22 kWh/1000h
- Power Consumption (Typical)
- 25 Watt
- Power Consumption Stand by
- 0.3 Watt
- Dimensions & Weight Details
- With stand - width: 56.36 cm - depth: 19.7 cm - height: 55.16 cm - weight: 6.87 kg , Without stand - width: 56.36 cm - depth: 5.24 cm - height: 37.88 cm - weight: 4.74 kg
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
Warranties (4)
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 4 Years On-Site | In Stock | £15.53 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site | In Stock | £30.10 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 1 Year On-Site | In Stock | £15.53 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Yrs On-Site for Monitor | In Stock | £6.01 |
Other bundles (1)
HP PC Mounting Bracket For Monitors | In Stock | £48.94 |
