Deploy a display designed specifically for clinicians with the HP Healthcare Edition HC270cr. It's built for easy, repeatable sanitization, DICOM Part 14 compliant for viewing medical images, and enhanced with single sign-on authentication support and collaboration tools for telemedicine.
Promote patient safety
Be ready for the next patient or user with our first clinical review display that is sanitizable with germicidal wipes every shift, every day. IEC 60601-1-2: 2014 compliance means you can use it in patient rooms and nurse's stations. -
Simplify daily security with a smart design
Login fast with a simple badge tap and spend more time on patient care with our first clinical review display to integrate a dual-band RFID reader to support single sign-on authentication. -
Hear every voice, read every facial expression
Create an optimal, collaborative telemedicine experience with a clinical review display that is certified for Skype for Business , and has an integrated RGB webcam, speakers and quick-start capacitive UCC buttons. -
Superb viewing for clinical images
View accurate, consistent medical images on a DICOM Part 14-compliant screen that is our first 27" diagonal 3.7 MP clinical review display with luminance uniformity, automatic backlight monitoring, auto image rotation, and user calibration.
- HP HC270cr Clinical Review Monitor - Healthcare - LED monitor - 3.7MP - colour - 27"
- LED-backlit LCD monitor - 3.7MP - colour - 27"
- RFID reader, USB 3.0 hub, 720p webcam, dual array microphone
- Panel Type
- AHVA
- Aspect Ratio
- 16:9
- Native Resolution
- QHD 2560 x 1440 at 60 Hz
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1 / 3000000:1 (dynamic)
- Response Time
- 12 ms (grey-to-grey)
- Input Connectors
- HDMI, 2xDisplayPort, VGA, USB-C
- Pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, anti-static
- Voltage
- AC 120/230 V
- Ceramic white
- 65.06 cm x 24.69 cm x 55.49 cm
- 8.81 kg
- Localisation
- English / United Kingdom
- IEC 60601-1-2, DICOM Part 14, low halogen
- 3-year warranty
- Display Type
- LED-backlit LCD monitor / TFT active matrix - 3.7MP - colour
- Diagonal Size
- 27"
- Built-in Devices
- Panel Type
- AHVA
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 350 cd/m²
- Contrast Ratio
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- BrightView
- Ceramic white
- 65.06 cm x 24.69 cm x 55.49 cm - with stand
- 8.81 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
- 2 x DisplayPort , HDMI , VGA , USB-C , USB 3.0 upstream , 2 x USB 3.0 downstream
Mechanical
- Tilt Angle
- -5/+25
- Swivel Angle
- 90
- Rotation Angle
- 90
- Cables Included
- DisplayPort cable , HDMI cable , VGA cable , USB-C cable , USB-B to USB-A cable
- Localisation
- Input Voltage
- AC 120/230 V
- Power Consumption (Typical)
- 65 Watt
- Power Consumption Stand by
- 0.5 Watt
- Dimensions & Weight Details
- With stand - width: 65.06 cm - depth: 24.69 cm - height: 55.49 cm - weight: 8.81 kg , Without stand - width: 65.06 cm - depth: 4.37 cm - height: 41.68 cm
- Limited warranty - parts and labour - 3 years
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 4 Years On-Site | In Stock | £22.36 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site | In Stock | £32.96 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 1 Year On-Site | In Stock | £5.89 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Yrs On-Site for Monitor | In Stock | £10.59 |
