HP Fusing Assembly 220V-240V
Quicklinx: 8RK5WS00 Mfr#: 9965
Type: Fuser kit
Technology: Laser
£84.16 ex VAT
£100.99 inc VAT
Your printer's fuser needs occasional maintenance and replacement to keep your machine performing optimally. This original HP RM1-6739 fuser kit is the best solution for your faulty fuser assembly. Don't let your worn and overused HP RM1-6739 fuser kit ruin the quality of your print work! Go for a genuine HP RM1-6739 fuser unit that is easy to install and use with any compatible unit. The HP RM1-6739-040CN fuser is one of the most important maintenance kits you should invest in to keep your machine working perfectly. If your HP RM1-6739 fuser is in need of replacement, make sure to address the problem promptly to avoid further damage to your machine.
HP - fuser kit
Fuser kit (220 - 240 V)
Printing Technology
Laser
Compatible with
LaserJet P2035, P2035n, P2055, P2055d, P2055dn, P2055x
Consumable
Consumable Type
Printing Technology
Laser
Compatible with
HP LaserJet P2035, P2035n, P2055, P2055d, P2055dn, P2055x
Type: Fuser kit
Technology: Laser
Brand: HP
