HP Flexible Thin Client t510, Eden X2 U4200, 2GB, no HDD,  Linux 32bit
Quicklinx: 878BWS00 Mfr#: H2P23AT#ABU
Support your virtualization environment with the HP t510 Thin Client – a significant upgrade performance with built-in energy efficiency, smart connectivity features and easy set-up guides for your PC-like multimedia needs.
  • Advanced performance
    The HP t510 Thin Client features a dual-core processor and DDR3-1066 SDRAM memory – built for a high grade end-user experience.
  • Windows-based support
    Experience broad application flexibility with a range of embedded operating system choices including versions of Microsoft Windows Embedded systems and HP's ThinPro Linux distribution. All support the security and experience expected for a thin client with write filters, local applications, a full browser, and terminal emulation.
  • Convenient connectivity
    The HP t510 features 6 USB 2.0 ports, a serial port, parallel port and power cord retention clip. Sustain wireless connectivity anywhere your network reaches with enterprise-ready integrated WiFi models.
  • HP Velocity for your network
    Improve network performance and the end-user experience with HP Velocity software.
  • Integrated management
    Store critical data on a secure centralized server or add Smart Cards for added security. HP Easy Tools guides users through set-up to Microsoft, Citrix, and VMware applications. Utilize HP Device manager, an enterprise-class thin client management software that allows you to view and change assets remotely.
  • Eco-highlights
    HP t510 Flexible Series Thin Clients are built with the environment in mind: low halogen components, Post-Consumer Recycled Plastics > 20% (excluding PCB), ENERGY STAR qualified, EPEAT Gold registered.
  • HP service and dependability
    Easy setup, easy manageability and now easy maintenance. With HP t510 Thin Clients, you can select from a range of HP Care Pack Services for support beyond standard.
HP Flexible t510 - tower - Eden X2 U4200 1 GHz - 2 GB - flash 1 GB
Thin client - tower
1 x VIA Eden X2 U4200 / 1 GHz (Dual-Core)
RAM
2 GB (installed) / 4 GB (max) - DDR3 SDRAM - PC3-8500
Hard Drive
Flash 1 GB
Optical Storage
No optical drive
Graphics Controller
VIA ChromotionHD 2.0 Shared Video Memory (UMA)
Audio Output
Stereo - integrated
1GbE
OS Provided
HP ThinPro
Software Included
Citrix ICA, Microsoft RDP, Rdesktop 1.6, HP ThinState Tools, HP Easy Tools, HP TeemTalk Terminal Emulator 7, HP Device Manager Agent, VMware View 4.6
5.84 cm x 21.59 cm x 21.97 cm
1.49 kg
Manufacturer Selling Program
HP Smart Buy
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Limited warranty - phone consulting - 3 years
Thin client
Product Form Factor
Tower
Built-in Devices
Speaker
Processor / Chipset
CPU
VIA Eden X2 U4200
Clock Speed
1 GHz
Number of Cores
Dual-Core
64-bit Computing
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Not upgradable
Chipset Type
VIA VX900
RAM
Installed Size
2 GB / 4 GB (max)
DDR3 SDRAM
Effective Memory Speed
1066 MHz
Rated Memory Speed
1066 MHz
Memory Specification Compliance
PC3-8500
SO-DIMM 204-pin
Slots
2 (Total)
Hard Drive
Flash
1 GB
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
Video Interfaces
VGA, DVI
Audio Output
Integrated
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
Input Device
Mouse, keyboard
Keyboard
USB
Mouse
USB
Integrated
Wake on LAN (WoL), DHCP support, PXE support
Slots
2 SO-DIMM 204-pin , 1 (total) / 1 (free) x PCIe Half Mini Card
6 x USB 2.0 (2 front, 2 rear) , 1 x serial , 1 x parallel , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) , 1 x headphones , 1 x microphone , 1 x DVI-I , 1 x DVI-D
DVI-VGA adapter
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
RoHS
HP Smart Buy
Power adapter
Power Provided
65 Watt
Operating System / Software
OS Provided
HP ThinPro
OS Certified
Microsoft Windows 2000 Server, Microsoft Windows Server 2003, Microsoft Windows Server 2003 Terminal Server, Microsoft Windows Server 2008 Terminal Server, Microsoft Windows Server 2000 Terminal Server, Citrix Presentation Server 4.0, Citrix XenDesktop 3.0, Citrix XenDesktop 4, Citrix XenApp 5, Citrix XenApp 6
Software
Sustainability Information
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
5.84 cm
21.59 cm
21.97 cm
1.49 kg
10 °C
10 - 90% (non-condensing)
