HP Ethernet 10Gb 2-port 570SFP+ Adapter
Quicklinx: DC48WS00 Mfr#: 718904-B21
Wired / Wireless: Wired
Protocol: 10 Gigabit Ethernet
Compatibility: PC
Type: Network adapter
£1,454.36 ex VAT
£1,745.23 inc VAT
Are you looking to improve you message rates by lowering latency? The higher message rates and lower latency of OpenOnload technology are now available with the HPE Ethernet 10Gb 2-port 570SFP+ Adapter, based on the SFC9020 controller from Solarflare. It out-performs standard Ethernet with lower CPU utilization and power consumption. This adds up to performance and scalability that are ideal for financial services environments. Now available as a fully supported factory installed option on the HPE ProLiant DL360p Gen8, and HPE DL380p Gen8 servers, the Ethernet 10Gb 2-port 570SFP+ Adapter comes with both low profile and standard brackets and has two SFP+ cages that enable connections with DACs as well as SR fiber optic modules. The HPE Ethernet 10Gb 2-port 570SFP+ Adapter supports high performance networking features such as VLAN tagging, low latency interrupts, TCP and UDP checksum offloading, MSI-X, NIC teaming (bonding), Receive Side Scaling (RSS), jumbo frames, and PXE boot.
  • Low Latency at High Message Rates
    Higher I/O performance-Each application receives an independent I/O channel.More efficient processing-Application and I/O processing share the same core.Greater scale out-More virtual NICs support more applications per server/.Optimized server utilization-Greater I/O workload per server with less CPU utilization and lower power consumption.
HPE 570SFP+ - network adapter - PCIe 2.0 x8 - 10Gb Ethernet x 2
Network adapter
Plug-in card
Interface (Bus) Type
PCI Express 2.0 x8
PCI Specification Revision
PCI 2.0
Ports
10Gb Ethernet x 2
10GbE
Data Transfer Rate
10 Gbps
Network / Transport Protocol
TCP/IP, UDP/IP
IEEE 802.3, IEEE 802.1Q, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.3ae, IEEE 802.3p, IEEE 802.1ab (LLDP)
ProLiant DL360p Gen8, DL360p Gen8 Base, DL360p Gen8 CMS, DL360p Gen8 Entry, DL360p Gen8 High Performance, DL360p Gen8 Special Server, DL380 Gen9 High Performance, DL380p Gen8 Special, DL388p Gen8 Base
Network adapter
Plug-in card
PCI Express 2.0 x8
PCI 2.0
Ports
10Gb Ethernet x 2
Wired
10 Gigabit Ethernet
Data Transfer Rate
10 Gbps
TCP/IP, UDP/IP
VLAN support, Jumbo Frames support, PXE support, TSO
2 x 10Gb Ethernet - SFP+
Compatible Slots
1 x PCI Express 2.0 x8
UL, BSMI, VCCI Class B ITE, BSMI CNS 13438 Class A, ICES-003, EN55024, CISPR 22, EN55022 Class B, WEEE, RoHS, FCC Part 15 B Class A, EN 61000-3-2:2006, EN 61000-3-3:2008
7.5 watt
5 °C
55 °C
5 - 95% (non-condensing)
HPE ProLiant DL360p Gen8, DL360p Gen8 Base, DL360p Gen8 CMS, DL360p Gen8 Entry, DL360p Gen8 High Performance, DL360p Gen8 Special Server, DL380 Gen9 High Performance, DL380p Gen8 Special, DL388p Gen8 Base
Compatibility: PC
Brand: HP
Price Range Ex VAT: £1000 - £1500
