Pair your device with the HP Essential USB Mouse for precise scrolling and clicking and smooth motion over a variety of surfaces without a mouse pad.
Simple USB connectivity
Connect the mouse to any USB port on your device. -
Fast navigation
Scroll quickly without a mouse pad, ball or roller with the optical sensor. -
Intuitive and familiar
Enjoy natural, comfortable left or right hand operation, and use the wheel on top as a third mouse button. -
World-class support
Get a one-year limited warranty.
- HP Essential - mouse - USB - black
- Mouse
- Connectivity Technology
- Wired - USB
- Black
- Orientation
- Right and left-handed
- 6.29 cm x 11.5 cm x 3.7 cm
- 90 g
- Movement Detection Technology
- Optical
- Buttons Qty
- 3
- Movement Resolution
- 800 dpi
- Scrolling wheel
- Cable Length
- 1.8 m
- OS Required
- Microsoft Windows Vista / 7 / 8 / 10
- 1-year warranty
- Mouse
- Orientation
- 6.29 cm
- 11.5 cm
- 3.7 cm
- 90 g
- Black
Input Device
- Wired
- Interface
- USB
- Optical
- Buttons Qty
- 3
- 800 dpi
- Cable Length
- 1.8 m
- Scrolling wheel
- 1 x USB
- TUV GS, VCCI, BSMI, FCC, cULus, KC, EAC
- OS Required
- Limited warranty - 1 year
