Add an extra layer of security to your notebook with the HP Essential Combination Lock, designed for any notebook with a standard lock slot.
Loop and lock with your own code
Route the 4 ft (1.22 m) vinyl-coated, galvanized steel cable around any secure object, attach to your notebook, and lock with the push-button mechanism and your unique four-digit combination. -
Room to move
The cable head swivels 360 degrees to help you position the cable as needed before you lock. -
Rest easy
Get the reassurance of a one-year limited warranty.
- HP Essential Combination Lock - security cable lock
- Product Type
- Security cable lock
- Product Material
- Galvanised steel
- Length
- 1.22 m
- Combination lock, 360 degree swivel capability, 4 digit code, vinyl-coated
- Product Type
- Product Material
- Galvanised steel
- Length
- 1.22 m
