Let nothing stand in your way
Power through your day with Windows 10 Pro and the powerful, sleek, thin, and light HP Elite x2. -
Delighting users, helping IT
Beautiful, serviceable, and built for enterprise-class durability, security and support. -
Self-healing safeguard
Start with a genuine HP BIOS every time. HP Sure Start Gen3 monitors in-memory BIOS, recovers the platform without user or admin intervention, restores the BIOS to a custom state, and is enterprise ready for centralized management. -
Creativity and collaboration go hand-in-hand
Explore your creative potential with the optional Wacom pen with app launch for a natural inking experience with 2048 levels of pressure, simultaneous pen and touch capability, and low palm sensitivity. -
Charge fast
Get up to 50% battery life in just 30 minutes of charging with an HP fast charging battery. -
Give your speakers a boost
HP Audio Boost balances loudness and clarity, and enhances bass for improved speech quality.
- HP Elite x2 1012 G2 - 12.3" - Intel Core i3 - 7100U - 4 GB RAM - 256 GB SSD - UK
- Product Type
- Tablet - with detachable keyboard
- Operating System
- Win 10 Pro 64-bit - English
- Processor
- Intel Core i3 (7th Gen) - 7100U / 2.4 GHz / 3 MB Cache
- Memory
- 4 GB LPDDR3 (provided memory is soldered)
- Storage
- 256 GB SSD - HP Z Turbo Drive G2, NVMe, TLC
- Display
- 12.3" LED backlight touchscreen 2736 x 1824 - 268 ppi
- Graphics
- Intel HD Graphics 620
- Input Device
- Keyboard, ClickPad
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2
- Battery
- 4-cell - up to 10.25 hours
- Accelerometer, ambient light sensor, proximity sensor, magnetometer, gyro sensor, hall sensor
- Dockable
- Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Dimensions (WxDxH) - tablet
- 30 cm x 21.385 cm x 0.805 cm
- 803 g
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition - English
Processor / Chipset
- CPU
- Intel Core i3 (7th Gen) 7100U / 2.4 GHz
- Number of Cores
- Dual-Core
- Cache
- 3 MB
- 64-bit Computing
- RAM
- 4 GB (provided memory is soldered)
- Technology
- LPDDR3 SDRAM
- Speed
- 1866 MHz
Storage
- Main Storage
- 256 GB SSD M.2 2280 PCIe - HP Z Turbo Drive G2, NVM Express (NVMe), triple-level cell (TLC)
Display
- 12.3" - IPS
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Yes (multi-touch)
- Resolution
- 2736 x 1824
- Widescreen
- Pixel Density (ppi)
- 268
- Image Brightness
- 450 cd/m²
- BrightView, Ultra Slim Design, ultra wide viewing angle, Corning Gorilla glass 4
- Keyboard Name
- HP Pro x2 612 G2 Collaboration Keyboard
Audio & Video
- Graphics Processor
- Camera
- Yes - 1080p
- Resolution
- 8 Megapixel (rear), 5 Megapixel (front)
- Video Resolutions
- 640 x 480, 1920 x 1080
- Frame Rate
- 30 frames per second
- Camera Features
- IR camera, low light enhancement, Windows Hello
- Sound
- Stereo speakers, two microphones
- Audio Features
- Output: noise-cancellation technology, Bang & Olufsen Audio
Input
- Keyboard Layout
- UK
- Volume control, ClickPad with gesture support, Wacom Active Pen technology
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- Intel Dual Band Wireless-AC 8265
- IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
- Technology
- 4-cell lithium polymer
- Capacity
- 47 Wh
- Run Time
- Up to 10.25 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 5 / 9 / 10 / 12 / 15 / 20 V
Connections & Expansion
- Interfaces Details
- USB-C 3.1 (supports Thunderbolt 3) , USB 3.0 , Headphone/microphone combo jack , Dock
- Memory Card Reader
- Yes (microSD, microSDHC, microSDXC)
Software
- Software Included
- Skype, HP SoftPaq Download Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, Windows Defender, HP Client Security, HP Velocity, HP BIOS Configuration Utility (free download), HP Client Catalogue (free download), HP Sure Connect, HP LAN-WLAN Protection, HP MIK for Microsoft SCCM (free download), HP BIOSphere Gen3, HP JetAdvantage, HP System Software Manager (free download), HP Advanced Noise Reduction Software, HP Driver Packs (free download)
- Integrated Options
- Dockable
- Security
- HP DuraKeys, HP Automatic Drive Lock, HP DriveLock, Power On Authentication, Pre-boot Authentication, HP Sure Start Gen 3, Master Boot Record Security
- Theft/Intrusion Protection
- Security Slot Type
- Kensington nano security slot
- Included Accessories
- Power adapter, keyboard, HP Elite x2 1012 G2 Collaboration Keyboard
- Low halogen
- Localization
- 803 g
- Dimensions (WxDxH) / Weight Details
- 30 cm x 21.93 cm x 1.355 cm / 1.156 kg - tablet with keyboard , 30 cm x 21.385 cm x 0.805 cm / 803 g - tablet
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 40 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 240 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 1.043 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 3.5 g @ RMS (random)
Essential Accessories (1)
Get more from your purchase from one of our essential accessories
HP USB-C Dock G5 Docking Station USB-C GigE 100 Watt | In Stock | £109.31 |
Warranty Packs (1)
Protect your investment by taking out one of our great value warranty packs
HP Care Pack Next Business Day Hardware Support - extended service agreement - 3 years - on-site | In Stock | £122.39 |
Other bundles (3)
HP USB-C To VGA Adapter | In Stock | £22.09 |
HP USB Travel Mouse | In Stock | £9.39 |
HP USB-C to HDMI 2.0 Adapter | In Stock | £46.71 |
