HP Envy 6020e All-in-One - Multifunction InkJet Colour Printer
Quicklinx: GDHCWS00 Mfr#: 223N4B#687
For everyone in the family. Print and scan documents, photos, and more. Set up and connect on any device, and get self-healing Wi-Fi . Choose HP+ at setup to receive 6 months of Instant Ink and an extended (up to 2 years) HP warranty.
This is an HP+ enabled printer. Choose HP+ at product setup to activate benefits. HP+ requires an HP account, ongoing connection to the internet, and exclusive use of Original HP Ink cartridges for the life of the printer. If you choose standard we remind you that this printer is intended to work only with cartridges that have new or reused HP electronic circuitry, and it uses dynamic security measures to block cartridges using modified or non-HP circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP electronic circuitry enables the use of reused, remanufactured, and refilled cartridges.
  • Seamless setup
    Get started fast with simple setup that guides you through each step, using HP Smart app.
  • Your reliable connection
    Reduce interruptions with self-healing Wi-Fi that keeps you connected.
  • Printing from your smartphone just got easier
    Easily print everyday documents and photos from your smartphone, using HP Smart app.
  • Amazing scanning, now on your smartphone
    With HP Smart app, get high-quality scanning and sharing – plus easily make copies – from your smartphone.
  • Tackle the essentials
    Get versatile performance and print, scan, and copy.
  • HP+, the cloud-connected, smart printing system
    An HP+ printer is ready when you are, more secure and productive than ever.
HP ENVY 6020e All-in-One - multifunction printer - colour - HP Instant Ink eligible
Multifunction printer
United Kingdom, Ireland
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max)
1000 pages
Recommended Monthly Volume
100 - 400 pages
Max Copying Speed
Up to 8 ppm (mono) / up to 4 ppm (colour)
Max Copying Resolution
Up to 300 x 300 dpi (mono) / up to 300 x 300 dpi (colour)
Max Printing Speed
Up to 10 ppm (mono) / up to 7 ppm (colour)
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Scanning
1200 x 1200 dpi
Original Size
216 x 297 mm (max)
Original Type
Sheets
Media Size
76.2 x 127 mm (min) - ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, cards, recycled paper, photo paper, light-weight paper, glossy paper, matte paper
Standard Media Capacity
100 sheets
Output Trays Capacity
25 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, Wi-Fi(ac)
AirPrint Enabled
Office Machine Features
Scan to e-mail, automatic paper sensor, HP Instant Ink, print from mobile devices, scan to PDF
AC 120/230 V (50/60Hz)
43.25 cm x 49.15 cm x 13.21 cm
5.22 kg
1-year warranty
Printing Technology
Ink-jet - colour
1000 pages
100 - 400 pages
USB 2.0, Wi-Fi(ac)
AirPrint Enabled
Standard Memory
256 MB
Max Supported Memory
256 MB
Copying
Max Copying Speed
Maximum Copies
9
Printing
Inkjet Technology
HP Thermal Inkjet
Nozzle Configuration
328 nozzles (black), 588 nozzles (colour)
Max Printing Speed
Ink Cartridge Configuration
1 pigment black cartridge, 1 colour cartridge (cyan, magenta, yellow)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, pigment black
4-ink
Printer Drivers / Emulations
PCL 3 GUI
Automatic Duplexing
First Print Out Time B/W
18 sec
First Print Out Time Colour
21 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Document & Media Handling
Max Original Size
216 x 297 mm
Supported Original Sizes
216 x 297 mm
Original Type
Sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Letter
Min Media Weight
60 g/m²
Max Media Weight
300 g/m²
Min Media Weight (lb)
16 lbs
Max Media Weight (lb)
80 lbs
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 101.6 x 152.4 mm, 76.2 x 127 mm, 127 x 177.8 mm, 203.2 x 254 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm)
Borderless Photo Sizes
216 x 297 mm
100 sheets
25 sheets
Input tray - 100 sheets size: 76.2 x 127 mm - Letter A (216 x 279 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 300 g/m²; weight (lbs): 16 lbs - 80 lbs , Output tray - 25 sheets
Speed Details
Printing: up to 20 ppm (A4) - B/W draft , Printing: up to 17 ppm (A4) - colour draft , Printing: up to 10 ppm - B/W (ISO) , Printing: up to 7 ppm - colour (ISO) , Copying: up to 8 ppm - B/W (ISO) , Copying: up to 4 ppm - colour (ISO)
1 x USB 2.0 - 4 pin USB Type B
Operating System Support
MS Windows 7 (32/64 bits), Windows 10 (32/64-bits), macOS 10.12, macOS 10.13, macOS 10.14, macOS 10.15
Power Consumption Standby
4 Watt
Power Consumption Sleep
1.7 Watt
Consumables Included
1 x ink cartridge (black) - HP 305 , 1 x ink cartridge (yellow/cyan/magenta) - HP 305
FCC Class B certified, FCC CFR47 Part 15, EN 62479:2010, EN 61000-3-3:2013, CISPR 24:2010, IEC 61000-3-3:2013, EN 55024:2010, EN 62311:2008, EN 61000-3-2:2014, IEC 60950-1:2005 + A1:2009 + A2:2013, EN 55032:2015, ICES-003 issue 6, EN 301 489-17 V3.1.1 (2017), CISPR 35, VCCI-CISPR 32:2016, CISPR 32:2015 Class B, EN 301 489-1 V2.1.1:2017, EN 55035:2017, EN 62368-1:2014+A11:2017, IEC 61000-3-2:2014, IEC 62368-1: 2014, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
Limited warranty - parts - 1 year
43.25 cm
49.15 cm
13.21 cm
5.22 kg
Shipping Width
47.4 cm
Shipping Depth
17.2 cm
Shipping Height
40.8 cm
Shipping Weight
6.35 kg
Sound Emission
56 dBA (operating)
5 °C
20 - 80% (non-condensing)
Ink (4)
GDHC HP 305XL High yeild black orginal In Stock £17.34
GDHC HP 305 Black Original Ink Cartridge In Stock £9.22
GDHC HP 305 Colour (Cyan, Magenta, Yellow) Original Ink Cartridge In Stock £9.22
GDHC HP 305XL High Yield Tri-Color Origin In Stock £15.89
Other bundles (1)
GDHC HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 3 Years Shipment In Stock £17.29
