Get versatile printing for your family. Easily create lab-quality photos and laser-quality text on the go – right from your smartphones and tablets. This e-all-in-one is designed to help you be creative and stay productive – at a great value.
Enjoy printing as connected as you are
Enjoy the easiest way to print from your smartphone or tablet – with or without a router or local wireless network.Easily connect this e-all-in-one to your local network and the Internet, wirelessly – right from your PC.Start printing quickly with easy setup from your smartphone, tablet or PC.Print from your iPhone , iPad , Android mobile devices, Amazon Kindle Fire – and many more. -
Save up to 70% on ink with HP Instant Ink
Print high-quality documents and photos in black-and-white and colour – all for the same low price.Print lab-quality colour photos in seconds for just a few pence, when you sign up for HP Instant Ink.Getting started with HP Instant Ink is quick and easy – learn more at hpinstantink.co.uk. -
Step up and create
Print borderless, lab-quality photos that dazzle and sharp documents with laser-quality text.Print 10 x 15 cm photos from your mobile device without switching paper using the separate photo paper tray.Walk up, edit and print right from the 6.75 cm (2.66-inch) touchscreen. -
Reduce your impact
Save paper and conserve resources – consume up to 50% less paper with automatic two-sided printing.Save energy with an e-all-in-one that's ENERGY STAR qualified.Reduce your environmental impact – easily recycle your Original HP Ink Cartridges for free.
- HP ENVY 5640 e-All-in-One - multifunction printer - colour
- Multifunction printer
- Localisation
- Western Europe, United Kingdom, Ireland, Nordics, Baltic Region
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- HP Thermal Inkjet - 4-ink
- Monthly Duty Cycle (max)
- 1000 pages
- Recommended Monthly Volume
- 300 - 400 pages
- Max Copying Speed
- Up to 10 ppm (mono) / up to 5 ppm (colour)
- Max Copying Resolution
- Up to 300 x 300 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Up to 12 ppm (mono) / up to 8 ppm (colour)
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
- Scanning
- 1200 x 1200 dpi
- Display
- 2.66"
- Original Size
- 216 x 297 mm (max)
- Original Type
- Sheets
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, cards, labels, iron-on transfers, photo paper
- Standard Media Capacity
- 125 sheets
- Output Trays Capacity
- 25 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, Wi-Fi(n)
- AirPrint Enabled
- Office Machine Features
- Scan to e-mail, HP Auto Wireless Connect
- Power
- AC 120/230 V (50/60Hz)
- 45.4 cm x 41 cm x 16.1 cm
- 6.82 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Ink-jet - colour
- 1000 pages
- 300 - 400 pages
- Display Diagonal Size
- 2.66"
- Display Features
- Touch screen
- Interface
- USB 2.0, Wi-Fi(n)
- AirPrint Enabled
- Localisation
- Standard Memory
- 128 MB
- Supported Flash Memory
- SD Memory Card
Copying
- Max Copying Speed
- Max Document Enlargement
- 200%
- Max Document Reduction
- 50%
- Maximum Copies
- 20
Printing
- Inkjet Technology
- HP Thermal Inkjet
- Nozzle Configuration
- 704 nozzles (black), 608 nozzles (colour)
- Ink Cartridge Configuration
- 1 black cartridge, 1 colour cartridge (cyan, magenta, yellow)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Printer Drivers / Emulations
- PCL 3 GUI
- First Print Out Time B/W
- 18 sec
- First Print Out Time Colour
- 22 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Document & Media Handling
- Max Original Size
- 216 x 297 mm
- Original Type
- Sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 75 g/m²
- Max Media Weight
- 250 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, C6 (114 x 162 mm), 76 x 127 mm, DL (210 x 99 mm)
- 125 sheets
- 25 sheets
- Input tray - 125 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 75 g/m² - 250 g/m² , Output tray - 25 sheets
- Speed Details
- Printing: up to 22 ppm (A4) - B/W draft , Printing: up to 21 ppm (A4) - colour draft , Printing: up to 12 ppm (A4) - B/W (ISO) , Printing: up to 8 ppm (A4) - colour (ISO) , Printing: 32 sec (10 x 15 cm (4"x6")) - photo normal , Copying: up to 21 ppm (A4) - B/W draft , Copying: up to 19 ppm (A4) - colour draft , Copying: up to 10 ppm (A4) - B/W (ISO) , Copying: up to 5 ppm (A4) - colour (ISO) , Scanning: up to 4 ppm
- 1 x USB 2.0 - 4 pin USB Type B
- Operating System Support
- MS Windows 7, MS Windows Vista, Apple Mac OS X 10.6, Apple Mac OS X 10.7, Apple Mac OS X 10.8, Windows 8, Windows 8.1
- Software Included
- Drivers & Utilities
- Voltage Required
- 13.95 Watt
- Power Consumption Standby
- 3.6 Watt
- Power Consumption Sleep
- 0.93 Watt
- CISPR 24, CISPR 22, CEM, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EN55022:2010, EN 301 489-1 V1.9.2, EN 301 489-17 V2.2.1, EN 55024:2010
- ENERGY STAR Certified
- Limited warranty - 1 year
- 45.4 cm
- 41 cm
- 16.1 cm
- 6.82 kg
- Shipping Width
- 49.7 cm
- Shipping Depth
- 20.5 cm
- Shipping Height
- 49.1 cm
- Shipping Weight
- 8.211 kg
- Sound Emission
- 49 dBA (operating)
- 5 °C
- 40 °C
- 20 - 80%
HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm | In Stock | £14.71 |
HP 62 Black Ink Cartridge | In Stock | £15.41 |
HP 62 Tri-color Ink Cartridge | In Stock | £18.38 |
HP Iron-on Transfers-12 sheet/A4/210 x 297 mm | In Stock | £13.72 |
