Print lab-quality photos and laser-sharp documents with this stylish and affordable wireless e-all-in-one. Print from virtually anywhere from your smartphone, tablet or internet-connected PC, and enjoy easy copying and scanning too.
Express your creativity with lab-quality photo printing
Create borderless, lab-quality photos in rich colour and print crisp, laser-sharp documents too.Do even more with easy colour copying and scanning – share photos, capture documents.Save time and paper with automatic two-sided printing and copying.Print and copy more for less with optional high-capacity XL ink cartridges. -
Get easy wireless printing from your smartphone or tablet
Enjoy easy wireless printing from virtually anywhere via your smartphone, tablet or internet-connected PC.Scan photos, documents and more directly to your mobile device with HP Printer Control.Use your Apple iPhone or iPad to control print, scan and copy features.Enjoy quick, hassle-free connection to your wireless network with HP Auto Wireless Connect. -
Do even more with this versatile and easy-to-use e-all-in-one
View, select and print photos directly via the colour touchscreen and card slots.Spend more time creating and less time waiting with fast print speeds.Compact form and sleek, stylish design – looks great in any room.
- HP ENVY 5530 e-All-in-One - multifunction printer - colour
- Multifunction printer
- Localisation
- Western Europe, United Kingdom, Ireland, Nordics, Baltic Region
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- HP Thermal Inkjet - 4-ink
- Monthly Duty Cycle (max)
- 1000 impressions
- Recommended Monthly Volume
- 300 - 400 pages
- Max Copying Speed
- Up to 21 ppm (mono) / up to 17 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 1200 dpi (colour)
- Max Printing Speed
- Up to 8.8 ppm (mono) / up to 5.2 ppm (colour)
- Max Printing Resolution
- Up to 1200 x 600 dpi (mono) / up to 4800 x 1200 dpi (colour)
- Scanning
- 1200 x 2400 dpi
- Display
- 2.65"
- Original Size
- 216 x 297 mm (max)
- Original Type
- Sheets
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, cards, labels, iron-on transfers, photo paper
- Standard Media Capacity
- 100 sheets
- Max Media Capacity
- 100 sheets
- Output Trays Capacity
- 30 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, Wi-Fi(n)
- AirPrint Enabled
- Office Machine Features
- Print from memory card, scan to e-mail, HP Auto Wireless Connect
- Power
- AC 120/230 V (50/60Hz)
- 44.5 cm x 33.4 cm x 12 cm
- 5.56 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Ink-jet - colour
- 1000 impressions
- 300 - 400 pages
- Display Diagonal Size
- 2.65"
- Display Features
- Touch screen
- Interface
- USB 2.0, Wi-Fi(n)
- AirPrint Enabled
- Localisation
- Standard Memory
- 128 MB
- Max Supported Memory
- 128 MB
- Supported Flash Memory
- SD Memory Card
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 50
- Copying Features
- ID Card Copy
Printing
- Inkjet Technology
- HP Thermal Inkjet
- Ink Cartridge Configuration
- 1 black cartridge, 1 colour cartridge (cyan, magenta, yellow)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, pigment black
- 4-ink
- Printer Drivers / Emulations
- PCL 3 GUI
- First Print Out Time B/W
- 19 sec
- First Print Out Time Colour
- 24 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 2400 dpi
- Interpolated Resolution
- 2400 x 2400 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Document & Media Handling
- Max Original Size
- 216 x 297 mm
- Original Type
- Sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 75 g/m²
- Max Media Weight
- 250 g/m²
- Supported Media Type
- Supported Media Sizes
- Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 76 x 127 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm), International C6 (114 x 162 mm)
- Borderless Photo Sizes
- 216 x 297 mm
- 100 sheets
- 100 sheets
- 30 sheets
- Input tray - 100 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 75 g/m² - 250 g/m² , Output tray - 30 sheets
- Speed Details
- Printing: up to 8.8 ppm - B/W (ISO) , Printing: up to 5.2 ppm - colour (ISO) , Copying: up to 6 ppm (A4) - B/W normal , Copying: up to 4 ppm (A4) - colour normal , Printing: 57 sec (10 x 15 cm (4"x6")) - photo normal , Printing: up to 21 ppm (A4) - B/W draft , Printing: up to 17 ppm (A4) - colour draft , Copying: up to 21 ppm (A4) - B/W draft , Copying: up to 17 ppm (A4) - colour draft , Copying: up to 21 ppm (Letter A) - B/W draft , Copying: up to 17 ppm (Letter A) - colour draft
- 1 x USB 2.0 - 4 pin USB Type B
- Operating System Support
- MS Windows 7, MS Windows XP SP3, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows Vista (64-bit versions), Apple Mac OS X 10.6, Apple Mac OS X 10.7, Apple Mac OS X 10.8, Windows 8, Windows 8 64-bit
- Software Included
- Drivers & Utilities
- Voltage Required
- 13.07 Watt
- Power Consumption Standby
- 2.51 Watt
- Power Consumption Sleep
- 0.7 Watt
- FCC Class B certified, CISPR 22 Class B, EN55022 Class B, FCC CFR47 Part 15, EN 62311, IEC 61000-3-3:2008, EN 61000-3-3:2008, ICES-003 issue 4 Class B, EN 61000-3-2:2006+A1:2009+A2:2009, IEC 62479, EN 62479:2010, IEC 62311, IEC60950-1:2005+A1:2009, VCCI V-3/2011.04, EN 55024:2010, EN 301 489-1, EN 301 489-17, EN 60950-1:2006+A11:2009+A1:2010+A12:2011
- ENERGY STAR Certified
- Limited warranty - 1 year
- 44.5 cm
- 33.4 cm
- 12 cm
- 5.56 kg
- Shipping Width
- 49.2 cm
- Shipping Depth
- 16.27 cm
- Shipping Height
- 40.02 cm
- Shipping Weight
- 6.5 kg
- Sound Emission
- 51 dBA (operating)
- 5 °C
- 40 °C
- 15 - 80% (non-condensing)
HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm | In Stock | £16.53 |
HP 301XL High Yield Tri-colour Original Ink Cartridge | In Stock | £33.58 |
