HP Envy 5030 AIO Multifunction Printer Colour Ink Jet
Quicklinx: DBGBWS00 Mfr#: M2U92B#BHC
Get affordable prints and increased versatility. Set up, connect, and print right from your smartphone, and produce high-quality photos and everyday documents while saving up to 70% on ink with HP Instant Ink. Print, scan, and copy with ease.
HP Envy 5030 All-in-One - multifunction printer - colour - HP Instant Ink eligible
Multifunction printer
Western Europe, United Kingdom, Ireland, Nordics, Baltic Region
Printing Technology
Ink-jet (colour)
Inkjet Technology
4-ink
Monthly Duty Cycle (max)
1000 pages
Recommended Monthly Volume
100 - 400 pages
Max Copying Speed
Up to 8 ppm (mono) / up to 4 ppm (colour)
Max Copying Resolution
Up to 600 x 300 dpi (mono) / up to 600 x 300 dpi (colour)
Max Printing Speed
Up to 10 ppm (mono) / up to 7 ppm (colour)
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Scanning
1200 x 1200 dpi
Display
2.2"
Original Size
Letter A (216 x 279 mm)/A4 (210 x 297 mm) (max)
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm), 216 x 594 mm (max)
Media Type
Plain paper, recycled paper, photo paper, light-weight paper, glossy paper, matte paper
Standard Media Capacity
100 sheets
Output Trays Capacity
25 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, Wi-Fi(n)
AirPrint Enabled
Office Machine Features
HP Auto Wireless Connect, HP Instant Ink
AC 120/230 V (50/60Hz)
44.5 cm x 36.7 cm x 12.8 cm
5.41 kg
1-year warranty
Printing Technology
Ink-jet - colour
1000 pages
100 - 400 pages
Display Diagonal Size
2.2"
Display Features
Touch screen
USB 2.0, Wi-Fi(n)
AirPrint Enabled
Standard Memory
256 MB
Max Supported Memory
256 MB
Copying
Max Copying Speed
Copying Features
ID Card Copy
Printing
Nozzle Configuration
328 nozzles (black), 588 nozzles (colour)
Max Printing Speed
Ink Cartridge Configuration
1 pigment black cartridge, 1 colour cartridge (cyan, magenta, yellow)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, pigment black
4-ink
Printer Drivers / Emulations
PCL 3 GUI
Automatic Duplexing
First Print Out Time B/W
16 sec
First Print Out Time Colour
19 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Document & Media Handling
Max Original Size
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
64 g/m²
Max Media Weight
250 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), C6 (114 x 162 mm), 101.6 x 152.4 mm, 76.2 x 127 mm, 127 x 177.8 mm, 203.2 x 254 mm, DL (210 x 99 mm)
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm)
Borderless Photo Sizes
ANSI A (Letter) (216 x 279 mm), 216 x 297 mm
100 sheets
25 sheets
Input tray - 100 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 64 g/m² - 250 g/m² , Output tray - 25 sheets
Speed Details
Scanning: up to 7 ppm - B/W normal , Scanning: up to 3 ppm - colour normal , Printing: up to 20 ppm (A4) - B/W draft , Printing: up to 17 ppm (A4) - colour draft , Printing: up to 10 ppm (A4) - B/W (ISO) , Printing: up to 7 ppm - colour (ISO) , Copying: up to 20 ppm (A4) - B/W draft , Copying: up to 14 ppm (A4) - colour draft , Printing: 52 sec (10 x 15 cm (4"x6")) - photo normal , Copying: up to 8 ppm - B/W (ISO) , Copying: up to 4 ppm - colour (ISO) , Copying: up to 20 ppm (Letter A) - B/W draft , Copying: up to 14 ppm (Letter A) - colour draft
1 x USB 2.0 - 4 pin USB Type B
Operating System Support
MS Windows 7, MS Windows XP SP2, MS Windows Server 2008 R2 x64 Edition, Windows 8, MS Windows Server 2012 x64 Edition, MS Windows Server 2008 R2 x64 Edition SP1, Windows 8.1, MS Windows Server 2008 SP1 (32/64-bits), MS Windows Server 2012 R2 x64 Edition, MS Windows Vista (32/64 bits), Apple Mac OS X 10.10, Windows 10, Apple Mac OS X 10.11, macOS 10.12, MS Windows Server 2016
Software Included
Drivers & Utilities, HP Photo Creations
14 Watt
Power Consumption Standby
3.75 Watt
Power Consumption Sleep
0.89 Watt
USB cable
Consumables Included
1 x Cartridge (black) - up to 120 pages - HP 304 , 1 x Cartridge (tricolour) - up to 100 pages - HP 304
BSMI, PSB, KCC, CAN/CSA C22.2 No. 60950-1-07, EN 62479:2010, CNS13438:2006, EN 61000-3-3:2013, EN 301 489-17 V2.1.1, CISPR 24:2010, EN 55024:2010, EN 55022:2010, EN 62311:2008, FCC Part 15 Class B, EN 61000-3-2:2014, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62479:2010, VCCI V-3/2013.04, KKC certified, IEC 62311:2007, ANSI/UL 60950-1 Second Edition, EN 55032 Class B, CISPR 32 Class B, ICES-003 issue 6, AS/NZS 60950-1:2015, Directive 2014/53/EU, EN 301 489-17, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
Limited warranty - 1 year
44.5 cm
36.7 cm
12.8 cm
5.41 kg
Shipping Width
48.7 cm
Shipping Depth
16.1 cm
Shipping Height
44.7 cm
Shipping Weight
6.45 kg
Sound Emission
51 dBA (operating)
5 °C
20 - 80% (non-condensing)
