HP Envy 34 - LED monitor - curved - 34"
Quicklinx: CXCZWS00 Mfr#: W3T65AA#ABU
This full-featured immersive display completely envelops your senses. Its sleek, micro-edge design makes it nearly impossible to look away. While its presentation brings your entertainment to life in ways you've only imagined. With an experience this electric, you'll never see entertainment the same way again.
  • 1,800R curved display
    By bringing the sides of the display even closer, the curved screen provides an incredibly realistic viewing experience and more expansive field of view.
  • Ultra WQHD Curved Display
    Give all your entertainment a new level of immersion with impressive 3440 x 1440 resolution. The curved display surrounds you with 5 million pixels for captivating definition and ultra-sharp details.
  • Power delivery with USB-C
    Simply plug your laptop or mobile device into the USB-C port while one connection lets you view your content on the big screen while the display charges your device.
  • Audio by Bang & Olufsen
    HP speakers, custom-tuned in collaboration with experts at Bang & Olufsen, deliver rich, authentic sound. Don't just listen – let the immersive experience move you.
  • HP Webcam
    With a great webcam it's never been easier to stay in touch and get your work done. Video chat with the family with clear, smooth quality.
  • 100Hz refresh rate
    Uncap your in-game frame rate, because with a 100Hz refresh rate this display is capable of clearer, high resolution details smoothly moving from frame to frame allowing for faster split-second reaction time.
HP ENVY 34 - LED monitor - curved - 34"
LED-backlit LCD monitor - 34"
Energy Class
Class C
Energy Consumption per Year
91 kWh
Power Consumption (On mode)
62 W
Curved Screen
USB 3.0 hub
Panel Type
VA
Aspect Ratio
21:9
Native Resolution
3440 x 1440 at 60 Hz
Pixel Pitch
0.232 mm
Brightness
350 cd/m²
Contrast Ratio
3000:1 / 5000000:1 (dynamic)
Response Time
6 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, DisplayPort
Display Position Adjustments
Tilt
Voltage
Black, silver
80.98 cm x 19.82 cm x 47.65 cm
11.14 kg
English / United Kingdom
Plug and Play, CSA, UL, VCCI, BSMI, NOM, TUV S, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, MEPS, KC, CECP, CEL, EAC, ISC, SEPA, low halogen, CE/EMC, ICE
1-year warranty
Display Type
Energy Class
Class C
91 kWh
Diagonal Size
34"
Curved Screen
Built-in Devices
USB 3.0 hub
Panel Type
VA
Aspect Ratio
21:9
Native Resolution
Pixel Pitch
0.232 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
6 ms (grey-to-grey)
Vertical Refresh Rate
100 Hz
Horizontal Refresh Rate
145 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
HDCP, anti-glare, Frame Rate Control (FRC), On-screen Digital Controls, Mercury free, arsenic-free glass, Bang & Olufsen audio
Black, silver
80.98 cm x 19.82 cm x 47.65 cm - with stand
11.14 kg
Audio
Speakers - stereo
Output Power / Channel
7 watt
2 x HDMI (HDCP) , DisplayPort (HDCP) , USB-C , 3 x USB 3.0 downstream , USB 3.0 upstream , Audio line-in/out
Mechanical
Tilt
Tilt Angle
-5/+20
Wall mount, L type screw driver
1 x power cable , 1 x USB cable , 1 x USB-C cable , 1 x HDMI cable , 1 x DisplayPort cable
Input Voltage
62 W
Power Consumption (Typical)
70 watt
Power Consumption Stand by
0.5 watt
Power Consumption (Off Mode)
0.43 watt
Included Software
HP Display Assistant
Dimensions & Weight Details
With stand - width: 80.98 cm - depth: 19.82 cm - height: 47.65 cm - weight: 11.14 kg , Without stand - width: 80.98 cm - depth: 10.24 cm - height: 39.53 cm - weight: 7.66 kg
Limited warranty - 1 year
5 °C
35 °C
20 - 80% (non-condensing)
