This full-featured immersive display completely envelops your senses. Its sleek, micro-edge design makes it nearly impossible to look away. While its presentation brings your entertainment to life in ways you've only imagined. With an experience this electric, you'll never see entertainment the same way again.
1,800R curved display
By bringing the sides of the display even closer, the curved screen provides an incredibly realistic viewing experience and more expansive field of view. -
Ultra WQHD Curved Display
Give all your entertainment a new level of immersion with impressive 3440 x 1440 resolution. The curved display surrounds you with 5 million pixels for captivating definition and ultra-sharp details. -
Power delivery with USB-C
Simply plug your laptop or mobile device into the USB-C port while one connection lets you view your content on the big screen while the display charges your device. -
Audio by Bang & Olufsen
HP speakers, custom-tuned in collaboration with experts at Bang & Olufsen, deliver rich, authentic sound. Don't just listen – let the immersive experience move you. -
HP Webcam
With a great webcam it's never been easier to stay in touch and get your work done. Video chat with the family with clear, smooth quality. -
100Hz refresh rate
Uncap your in-game frame rate, because with a 100Hz refresh rate this display is capable of clearer, high resolution details smoothly moving from frame to frame allowing for faster split-second reaction time.
- HP ENVY 34 - LED monitor - curved - 34"
- LED-backlit LCD monitor - 34"
- Energy Class
- Class C
- Energy Consumption per Year
- 91 kWh
- Power Consumption (On mode)
- 62 W
- Curved Screen
- USB 3.0 hub
- Panel Type
- VA
- Aspect Ratio
- 21:9
- Native Resolution
- 3440 x 1440 at 60 Hz
- Pixel Pitch
- 0.232 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 3000:1 / 5000000:1 (dynamic)
- Response Time
- 6 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- 2xHDMI, DisplayPort
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black, silver
- 80.98 cm x 19.82 cm x 47.65 cm
- 11.14 kg
- Localisation
- English / United Kingdom
- Plug and Play, CSA, UL, VCCI, BSMI, NOM, TUV S, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, MEPS, KC, CECP, CEL, EAC, ISC, SEPA, low halogen, CE/EMC, ICE
- 1-year warranty
- Display Type
- Energy Class
- Class C
- 91 kWh
- Diagonal Size
- 34"
- Curved Screen
- Built-in Devices
- USB 3.0 hub
- Panel Type
- VA
- Aspect Ratio
- 21:9
- Native Resolution
- Pixel Pitch
- 0.232 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 100 Hz
- Horizontal Refresh Rate
- 145 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- HDCP, anti-glare, Frame Rate Control (FRC), On-screen Digital Controls, Mercury free, arsenic-free glass, Bang & Olufsen audio
- Black, silver
- 80.98 cm x 19.82 cm x 47.65 cm - with stand
- 11.14 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 7 watt
- 2 x HDMI (HDCP) , DisplayPort (HDCP) , USB-C , 3 x USB 3.0 downstream , USB 3.0 upstream , Audio line-in/out
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- Included Accessories
- Wall mount, L type screw driver
- Cables Included
- 1 x power cable , 1 x USB cable , 1 x USB-C cable , 1 x HDMI cable , 1 x DisplayPort cable
- Localisation
- Input Voltage
- 62 W
- Power Consumption (Typical)
- 70 watt
- Power Consumption Stand by
- 0.5 watt
- 0.43 watt
- Included Software
- HP Display Assistant
- Dimensions & Weight Details
- With stand - width: 80.98 cm - depth: 19.82 cm - height: 47.65 cm - weight: 11.14 kg , Without stand - width: 80.98 cm - depth: 10.24 cm - height: 39.53 cm - weight: 7.66 kg
- Limited warranty - 1 year
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
