HP Envy 32" 2560x1440 7ms HDMI DisplayPort MHL LED Monitor
Quicklinx: BSRGWS00 Mfr#: N9C43AA#ABU
The HP ENVY 32 Media Display is a mind-blowing Quad HD monitor that elevates all your work and entertainment to new limits. With wide-angle viewing, brilliant imagery, modern streamlined design, and broad port connectivity, immerse yourself into a unique blend of advanced display with media functionality.
  • Stunning views
    A 81.28 cm (32") diagonal wide-viewing angle screen makes it easy to take in all 3.6 million pixels of this Quad HD display. Wow. Is there anything more to say?
  • An exceptionally rich audio experience
    State-of-the-art Audio by Bang & Olufsen transforms your PC into a soundstage where entertainment comes alive to awaken your senses with sound you can feel. Designed for true audio perfection on a display.
  • Upscaled connectivity
    Connect a wide range of devices like tablets and phones through MHL, HDMI, USB 2.0 or DisplayPort, with optimized upscaling for flawless mobile streaming.
  • No stuttering
    Put an end to choppy gameplay and broken frames with AMD FreeSync . Now you can enjoy fluid performance at virtually any frame rate.
HP ENVY 32 Media Display - LED monitor - 32"
LED-backlit LCD monitor - 32"
Energy Class
Class A
Energy Consumption per Year
60 kWh
Power Consumption (On mode)
41 W
Adaptive-Sync Technology
AMD FreeSync
USB 2.0 hub
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 60 Hz
Pixel Pitch
0.276 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1 / 10000000:1 (dynamic)
Response Time
7 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, DisplayPort, MHL
Display Position Adjustments
Tilt
Voltage
White, jack black, natural silver
86.16 cm x 17.89 cm x 52.2 cm
10.7 kg
English / United Kingdom
Plug and Play, VCCI, BSMI, NOM, TUV S, CB, CCC, FCC, ISO 9241-307, KCC, ICES, CECP, CEL, EPA, ISC, SEPA
1-year warranty
Display Type
Energy Class
Class A
60 kWh
Diagonal Size
32"
AMD FreeSync
Built-in Devices
USB 2.0 hub
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
7 ms (grey-to-grey)
Vertical Refresh Rate
60 Hz
Horizontal Refresh Rate
90 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
HDCP, anti-glare, Mercury free, arsenic-free glass, Bang & Olufsen audio
86.16 cm x 17.89 cm x 52.2 cm - with stand
10.7 kg
Audio
Speakers - stereo
Output Power / Channel
6 Watt
MHL (HDCP) , 2 x HDMI (HDCP) , DisplayPort (HDCP) , Audio line-out , 2 x USB 2.0 downstream , USB 2.0 upstream
Mechanical
Tilt
Tilt Angle
-5/+25
Wall mountable
Wall mount
1 x USB cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x HDMI cable - 1.8 m
Input Voltage
41 W
Power Consumption (Typical)
50 Watt
Power Consumption Stand by
1 Watt
Power Consumption Sleep
0.5 Watt
Included Software
HP Display Assistant
Dimensions & Weight Details
Without stand - width: 86.16 cm - depth: 5.82 cm - height: 43.36 cm - weight: 9 kg , With stand - width: 86.16 cm - depth: 17.89 cm - height: 52.2 cm - weight: 10.7 kg
Limited warranty - 1 year
5 °C
35 °C
20 - 70% (non-condensing)
