Thin is in, and this HP ENVY laptop delivers. This superbly sleek, elegantly designed body packs the power of a high-performance PC. It's portable. It's beautiful. It's going to be your new infatuation.
Thin just got thinner
At just 12.9 mm, the thinnest notebook we’ve ever made is guaranteed to intrigue, with an artfully-crafted all-metal body and stunningl Quad HD+ display.
Engineered for excellence
With 6th generation Intel® Core™ i5 processors2, up to 128 GB SSD, and a full range of ports, performance and supreme thinness go hand in hand.
Impressive endurance
Don’t let the size fool you. This lightweight beauty packs a heavy-hitting battery.
High performance - Intel® Core™ processors deliver cutting-edge performance. With dual-core processors you’ll enjoy stunning visuals, effortless multitasking, increased speed and enhanced security to help you create, play, entertain and achieve.
6th generation Intel processors - Enhance your computing experience with the latest processors from Intel.
Windows 10 Home - Windows 10 Home is here. Do great things.
Sleek design - Easily take this thin and light PC from room to room or on the road.
QHD+ display - Spectacular entertainment from ultra-wide viewing angles with the incredible image quality of QHD+.
Bang & Olufsen with dual speakers - Dual speaker sound, designed for true audio perfection on a PC.
HP Solid-State Drive - Load your apps fast with quick and efficient HP Solid-State Drives.
Backlit keyboard - Keep going comfortably even in darker environments.
HP SimplePass security - Access online accounts5 with the swipe of a finger.
Power on. - Charge devices even in sleep mode with HP USB Sleep and Charge.
Packed with ports - Connect easily. - Windows 10 Home or other operating systems available
Windows 10 Home
Windows 10 Home is here. Do great things confidently with the familiar feel of Windows - only better. -
Sleek design
Easily take this thin and light PC from room to room or on the road. Take it anywhere and look sharp. -
Dual-speakers with Audio by Bang & Olufsen transforms your PC into a soundstage where entertainment comes alive with sound you can feel. Designed for true audio perfection on a PC. -
Solid-State Drive
Meet the lightning-fast drive that can keep up with your every demand. Load your apps fast with quick and efficient Solid-State Drives. -
Faster, quieter, and with more features, the 6th generation of Intel Core processors enhances your computing experience like never before. -
Backlit keyboard
Keep going even in dimly lit rooms or aboard red-eye flights. With an illuminated keyboard, you can type comfortably in more environments.
- HP ENVY Laptop 13-d002na - 13.3" - Intel Core i7 - 6500U - 8 GB RAM - 256 GB SSD - UK
- Product Type
- Notebook
- Operating System
- Win 10 Home 64-bit - English
- Processor
- Intel Core i7 (6th Gen) - 6500U / 2.5 GHz, up to 3.1 GHz / 4 MB Cache
- Memory
- 8 GB DDR3L (provided memory is soldered)
- Storage
- 256 GB SSD
- Display
- 13.3" WLED 1920 x 1080 / Full HD
- Graphics
- Intel HD Graphics 520
- Input Device
- Imagepad
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac
- Battery
- 3-cell
- Security
- Trusted Platform Module (TPM) Security Chip, fingerprint reader
- Natural silver, aluminium (cover)
- 32.65 cm x 22.6 cm x 1.29 cm
- 1.36 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 1 year - pick-up and return
- Product Type
- Notebook
- Operating System
- Windows 10 Home 64-bit Edition - English
Processor / Chipset
- CPU
- Intel Core i7 (6th Gen) 6500U / 2.5 GHz
- Max Turbo Speed
- 3.1 GHz
- Number of Cores
- Dual-Core
- Cache
- 4 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 8 GB (provided memory is soldered)
- Technology
- DDR3L SDRAM
- Form Factor
- SO-DIMM 204-pin
Storage
- Main Storage
- 256 GB SSD M.2
Display
- 13.3" - IPS
- LCD Backlight Technology
- WLED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Full HD anti-glare
Audio & Video
- Graphics Processor
- Camera
- Yes - HD
- Camera Features
- HP TrueVision HD
- Sound
- Stereo speakers, two microphones
- Audio Features
- Output: Bang & Olufsen Audio
Input
- Keyboard, imagepad
- Keyboard Layout
- UK
- Multi-touch touchpad, gesture function
Communications
- Wireless
- Miracast
- Technology
- 3-cell lithium polymer
- Capacity
- 45 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt
Connections & Expansion
- HDMI , Headphone/microphone combo jack , 3 x USB 3.0
- Memory Card Reader
- Yes (SD Card)
Software
- Software Included
- Skype, EverNote, Netflix, HP SimplePass, McAfee LiveSafe (30 days trial), Dropbox (25 GB Cloud Storage) (free for 6 months), HP Lounge
- Security
- Security lock slot (cable lock sold separately), power-on password, HP USB Boost
- Included Accessories
- Power adapter
- Localization
- 1.36 kg
Sustainability Information
- ENERGY STAR Certified
