HP ElitePad Serial Cable
Quicklinx: 8K5JWS00 Mfr#: H3N50AA
PC ports. Minus the PC. Expand what you can do with your HP ElitePad, whether it's inside retail or out in the field. Attach barcode scanners, diagnostic tools, and more.*
HP ElitePad Serial Adapter - serial adapter - 70-pin dock connector to DB-9 - 14.89 cm
Serial adapter
Length
14.89 cm
Connector
70-pin dock connector - male
Connector (Second End)
9 pin D-Sub (DB-9) - female
Elite x2 1011 G1; ElitePad 1000 G2, 900 G1
Serial adapter
Length
14.89 cm
Connector
UL, VCCI, C-Tick, BSMI, EN55022, ICES-003, EN55024, FCC Part 15 B, RoHS, EN 61000, KC
HP Elite x2 1011 G1 , HP ElitePad 1000 G2, 900 G1
