HP EliteOne 800 G4 Core i5-8500 8GB 1TB All-In-One Windows 10 Pro
Quicklinx: DVBTWS00 Mfr#: 4KX02ET#ABU
Processor Type: Core i5
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 8GB
Hard Drive Capacity: 1TB
Storage Type: HDD
  • Core i5
  • IEEE 802.11n
26 in stock
£623.87 ex VAT
£748.64 inc VAT
Modernize any workspace with an AiO PC that makes a great first impression. The HP EliteOne AiO delivers serious performance, engaging collaboration, multi-faceted security, and purposeful manageability in a stunning and sleek 23.8-inch diagonal micro-edge bezel design.
  • Amazing from any angle
    Count on this purposefully designed AiO to impress. Work in style on the elegant HP EliteOne 800 AiO with its thin profile, micro-edge anti-glare touch display, and superb cable management.
  • Performance first
    Users will enjoy powerful 8th Gen Intel Core processors, Intel Optane memory and optional AMD Radeon discrete graphics.
  • Strong security, powerful manageability
    Get powerful protection and simplified management from our most secure and manageable PCs. HP Sure Start Gen4 protects against BIOS attacks while the HP Manageability Integration Kit allows you to easily manage devices through Microsoft System Center Configuration Manager.
  • See and hear them clearly
    Collaborate with the sharpness of a face-to-face meeting on the 23.8-inch diagonal FHD touch display with crystal-clear audio and either a front-facing pop-up IR camera with a rear-facing FHD Camera, or a front facing pop-up FHD camera.
HP EliteOne 800 G4 - all-in-one - Core i5 8500 3 GHz - 8 GB - 1 TB - LED 23.8" - QWERTY UK
Personal computer - all-in-one
Platform Technology
Intel vPro Technology
1 x Intel Core i5 (8th Gen) 8500 / 3 GHz (4.1 GHz) (6-core)
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2
Cache Memory
9 MB
Cache Per Processor
9 MB
RAM
8 GB (installed) / 32 GB (max) - DDR4 SDRAM - PC4-21333
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
1 x 1 TB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD-Writer
Card Reader
5 in 1
Monitor
23.8" - LED - 1920 x 1080 (Full HD) - 16:9 - touchscreen
Graphics Controller
Intel UHD Graphics 630
Camera
Audio Output
Stereo
GigE, 802.11a, 802.11b/g/n, 802.11ac, Bluetooth 5.0
OS Provided
53.96 cm x 5.38 cm x 34.179 cm
6.03 kg
Platform Technology
Personal computer
Product Form Factor
All-in-one
Built-in Devices
Speaker, fingerprint reader
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Max Turbo Speed
4.1 GHz
Number of Cores
6-core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Chipset Type
Intel Q370
Cache Memory
Installed Size
9 MB
Cache Per Processor
9 MB
RAM
Installed Size
8 GB / 32 GB (max)
DDR4 SDRAM
Effective Memory Speed
2666 MHz
Rated Memory Speed
2666 MHz
Memory Specification Compliance
PC4-21333
SO-DIMM 260-pin
Slots
2 (Total) / 1 (empty)
Configuration Features
1 x 8 GB
Hard Drive
HDD
1 x 1 TB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
DVD-Writer
Card Reader
5 in 1 card reader
Supported Flash Memory Cards
SD Memory Card, SDHC Memory Card, SDXC Memory Card, SDHC UHS-I Memory Card, SDHC UHS-II Memory Card
Monitor
Monitor Type
LED - IPS
Touchscreen
Yes (10-point multi-touch)
Diagonal Size
23.8"
Native Resolution
Widescreen Display
Image Aspect Ratio
16:9
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Pixel Pitch
0.2745 mm
Image Brightness
250 cd/m²
Image Contrast Ratio
1000:1
Monitor Features
Anti-glare, 72% colour gamut, Projected Capacitive Touch (PCT) technology
Graphics Controller
Graphics Processor
Video Interfaces
HDMI, DisplayPort
HDCP Compatible
Max Monitors Supported
3
Audio Output
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
Speakers
Bang & Olufsen sound bar
Speakers Included
2 x right / left channel
Camera
Camera
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP Business Slim Keyboard
Wireless
Localization & Layout
QWERTY UK
Mouse
Wireless
Audio Input
Dual array microphone
Ethernet Controller
Intel I219-LM
Wireless LAN Supported
Wireless NIC
Intel Wireless-AC 9560
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 5.0
Remote Management Protocol
SNMP 2
Wake on LAN (WoL), auto-uplink (auto MDI/MDI-X)
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.3x, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.3az, IEEE 802.11ac, Bluetooth 5.0
Bays
1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 0 (free) x external , 1 (total) / 0 (free) x internal 2.5"
Slots
1 (total) / 0 (free) x M.2 Card - 2230 , 2 (total) / 2 (free) x M.2 Card - 2280/2230
2 x USB 3.1 Gen 2 (one of them is fast-charging) , 2 x USB 3.1 Gen 1 , 2 x USB 3.1 Gen 2 (wake functionality) , 1 x USB-C 3.1 Gen 2 , 1 x LAN (Gigabit Ethernet) , 1 x DisplayPort , 1 x HDMI , 1 x audio line-out , 1 x headphones , 1 x headphones/microphone
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
VESA Mounting Interface
100 x 100 mm
ACPI, CCC, RoHS, WEEE, CECP, SEPA, low halogen
Power supply
Nominal Voltage
Power Provided
180 Watt
Efficiency
90%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition English
Software
HP Support Assistant, HP ePrint, HP Hotkey Support, Password Manager, HP Velocity, HP BIOSphere, HP BIOS Configuration Utility (free download), HP Client Catalogue (free download), Absolute Persistence, HP Driver Packs, HP BIOS Config Utility, HP JumpStart, HP Workwise, HP Noise Cancellation, HP Wireless Wakeup, HP System Software Manager (free download), HP PhoneWise, HP Client Security Suite Gen4, HP SureStart Gen4, Ivanti Management Suite, HP Sure Run, HP Sure Recover, HP Management Integration Kit for Microsoft System Center Configuration Manager Gen 2
Dimensions & Weight Details
53.96 cm - 5.38 cm - 34.179 cm - 6.03 kg - without stand
53.96 cm
5.38 cm
34.179 cm
6.03 kg
Shipping Width
69 cm
Shipping Depth
25.6 cm
Shipping Height
54.5 cm
Shipping Weight
9.4 kg
5 °C
45 °C
5 - 90%
HP EliteOne 800 G4 Core i5-8500 8GB 1TB All-In-One Windows 10 Pro Bundle deal on HP EliteOne 800 G4 Core i5-8500 8GB 1TB All-In-One Windows 10 Pro
£809.09
saving £8.33
£723.63
Storage Type: HDD
Processor Model: I5-8500
Type: Personal computer
Case Style: All-in-one
Display: Integrated
Optical Storage: DVD-Writer
Brand: HP
Price Range Ex VAT: 500 - 750
