Modernize any workspace with an AiO PC that makes a great first impression. The HP EliteOne AiO delivers serious performance, engaging collaboration, multi-faceted security, and purposeful manageability in a stunning and sleek 23.8-inch diagonal micro-edge bezel design.
Amazing from any angle
Count on this purposefully designed AiO to impress. Work in style on the elegant HP EliteOne 800 AiO with its thin profile, micro-edge anti-glare touch display, and superb cable management. -
Performance first
Users will enjoy powerful 8th Gen Intel Core processors, Intel Optane memory and optional AMD Radeon discrete graphics. -
Strong security, powerful manageability
Get powerful protection and simplified management from our most secure and manageable PCs. HP Sure Start Gen4 protects against BIOS attacks while the HP Manageability Integration Kit allows you to easily manage devices through Microsoft System Center Configuration Manager. -
See and hear them clearly
Collaborate with the sharpness of a face-to-face meeting on the 23.8-inch diagonal FHD touch display with crystal-clear audio and either a front-facing pop-up IR camera with a rear-facing FHD Camera, or a front facing pop-up FHD camera.
- HP EliteOne 800 G4 - all-in-one Core i5 8500 3 GHz - vPro - 8 GB - HDD 1 TB - LED 23.8" - UK
- Personal computer - all-in-one
- Platform Technology
- Intel vPro Platform
- Localisation
- Processor
- Intel Core i5 (8th Gen) 8500 / 3 GHz (up to 4.1 GHz, (6-core)
- Processor Main Features
- Hyper-Threading Technology, Intel Turbo Boost Technology 2
- Cache Memory
- 9 MB
- Cache Per Processor
- 9 MB
- RAM
- 8 GB (installed) / 32 GB (max) - DDR4 SDRAM - PC4-21333
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- HDD 1 TB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- DVD-Writer
- Card Reader
- 5 in 1
- Monitor
- 23.8" - LED - 1920 x 1080 (Full HD) - 16:9 - touchscreen
- Graphics Controller
- Intel UHD Graphics 630
- Camera
- Audio Output
- Stereo
- Networking
- 1GbE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 5.0
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- Software Included
- HP Support Assistant, HP ePrint, HP Hotkey Support, Password Manager, HP Velocity, HP BIOSphere, HP BIOS Configuration Utility (free download), HP Client Catalogue (free download), Absolute Persistence, HP Driver Packs, HP BIOS Config Utility, HP JumpStart, HP Workwise, HP Noise Cancellation, HP Wireless Wakeup, HP System Software Manager (free download), HP PhoneWise, HP Client Security Suite Gen4, HP SureStart Gen4, Ivanti Management Suite, HP Sure Run, HP Sure Recover, HP Management Integration Kit for Microsoft System Center Configuration Manager Gen 2
- 53.96 cm x 5.38 cm x 34.179 cm
- 6.03 kg
- Manufacturer Selling Program
- HP Smart Buy
- Limited warranty - parts and labour - 3 years - on-site
- Personal computer
- Product Form Factor
- All-in-one
- Built-in Devices
- Speaker, fingerprint reader
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 3 GHz
- Max Turbo Speed
- 4.1 GHz
- Number of Cores
- 6-core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- Chipset Type
- Intel Q370
Cache Memory
- Installed Size
- 9 MB
- 9 MB
RAM
- Installed Size
- Technology
- DDR4 SDRAM
- Effective Memory Speed
- 2666 MHz
- Rated Memory Speed
- 2666 MHz
- Memory Specification Compliance
- PC4-21333
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 1 (empty)
- Configuration Features
- 1 x 8 GB
Hard Drive
- HDD
- Capacity
- 1 x 1 TB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- DVD-Writer
Card Reader
- 5 in 1 card reader
- Supported Flash Memory Cards
- SD Memory Card, SDHC Memory Card, SDXC Memory Card, SDHC UHS-I Memory Card, SDHC UHS-II Memory Card
Monitor
- Monitor Type
- LED - IPS
- Touchscreen
- Yes (10-point multi-touch)
- Diagonal Size
- 23.8"
- Native Resolution
- Widescreen Display
- Image Aspect Ratio
- 16:9
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Colour Gamut
- 72%
- Pixel Pitch
- 0.2745 mm
- Image Brightness
- 250 cd/m²
- Image Contrast Ratio
- 1000:1
- Monitor Features
- Anti-glare, Projected Capacitive Touch (PCT) technology
Graphics Controller
- Graphics Processor
- Video Interfaces
- HDMI, DisplayPort
- HDCP Compatible
- Max Monitors Supported
- 3
Audio Output
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 192 kHz
- Speakers
- Bang & Olufsen sound bar
- Speakers Included
- 2 x right / left channel
Camera
- Camera
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- HP Business Slim Keyboard
- Connectivity
- Wireless
- Localization & Layout
- UK
Mouse
- Connectivity
- Wireless
Audio Input
- Dual array microphone
- Ethernet Controller
- Intel I219-LM
- Wireless LAN Supported
- Wireless NIC
- Intel Wireless-AC 9560
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 5.0
- Remote Management Protocol
- SNMP 2
- Wake on LAN (WoL), auto-uplink (auto MDI/MDI-X)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.3x, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.3az, IEEE 802.11ac, Bluetooth 5.0
- Bays
- 1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 0 (free) x external , 1 (total) / 0 (free) x internal 2.5"
- Slots
- 1 (total) / 0 (free) x M.2 Card - 2230 , 2 (total) / 2 (free) x M.2 Card - 2230/2280
- 2 x USB 3.1 Gen 2 (one of them is fast-charging) , 2 x USB 3.1 Gen 1 , 2 x USB 3.1 Gen 2 (wake functionality) , 1 x USB-C 3.1 Gen 2 , 1 x LAN (Gigabit Ethernet) , 1 x DisplayPort , 1 x HDMI , 1 x audio line-out , 1 x headphones , 1 x headphones/microphone
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- VESA Mounting Interface
- 100 x 100 mm
- ACPI, CCC, RoHS, WEEE, CECP, SEPA, low halogen
- HP Smart Buy
- Power supply
- Voltage Required
- Power Provided
- 180 Watt
- Efficiency
- 90%
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Windows 10 Pro 64-bit Edition English
- Software
- Dimensions & Weight Details
- 53.96 cm - 5.38 cm - 34.179 cm - 6.03 kg - without stand
- 53.96 cm
- 5.38 cm
- 34.179 cm
- 6.03 kg
- Shipping Width
- 69 cm
- Shipping Depth
- 25.6 cm
- Shipping Height
- 54.5 cm
- Shipping Weight
- 9.4 kg
- 5 °C
- 45 °C
- 5 - 90%
Warranties (6)
HP 3 Year NBD On-Site Optional Customer Self Repair Desktop/Workstation Only Hardware Service | In Stock | £17.66 |
HP Care Pack Next Business Day HW Support Post Warranty Extended Service Agreement 1 Year On-Site | In Stock | £16.46 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site | In Stock | £49.43 |
HP Care Pack NBD Hardware Support with Disk Retention Extended Service Agreement 3 Years On-Site | In Stock | £33.19 |
HP Care Pack NBD HW Support w/ Defective Media Retention Extended Service Agreement 4 Years On-Site | In Stock | £55.31 |
HP Care Pack NBD Hardware Support with Disk Retention Extended Service Agreement 5 Years On-Site | In Stock | £77.67 |
Other bundles (2)
HPE DisplayPort DVI-D Adapter | In Stock | £11.55 |
HP USB-C to USB 3.0 | In Stock | £20.25 |
