HP EliteOne 800 G2 Intel Core i5 6500 8GB 256GB SSD
Quicklinx: CN2XWS00 Mfr#: T4J21EA#ABU
  • Core i5
  • IEEE 802.11n
Elegant, sleek, user-friendly, and designed to perform, the HP EliteOne 800 is ready to deploy in demanding environments, with manageability and security, enterprise-class collaboration technologies, and touchscreen configurations.
Place it here, there, and everywhere
Deploy this redesigned, stylish All-in-One with a 58.4 cm (23") diagonal FHD display anywhere you need a powerhouse PC. Its slim design and integrated cable management make an impression at reception, on an executive’s desk or mounted on a wall.
Deeply secure
Help secure your PC with comprehensive hardware and software tools like an optional fingerprint reader and HP BIOSphere with Sure Start’s customizable BIOS-level passwords.
Power-packed performance
Drive your most demanding workloads with an All-in-One powered by fast 6th Gen Intel® Core™ processors, plus AMD Radeon™ R9 360 discrete graphics with 2 GB GDDR5 for your most challenging use cases.
Count on premier audiovisual clarity
Collaborate naturally with Cortana on Windows 10 Pro, optional 10-point capacitive touch, Audio by Bang & Olufsen, HP Clear Sound Amp, HP Noise Reduction Software, and a 2MP HD webcam.
  • Let nothing stand in your way
    Help protect from today's security threats and maximize management and productivity features for business with Window 10 Pro.
  • Ready to run, and upgrade
    Make expansion and upgrades a snap with a tool-less rear access panel.
  • World-class management
    Simplify IT manageability with Intel vPro and Windows 10 plus HP Common Core BIOS, which enables easy management of your entire fleet of HP devices.
  • Tested to go the distance
    Rest easy with a PC that passed 120,000 hours of testing and is designed to undergo MIL-STD 810G testing.
  • Consistently stagger deployments
    Get the same HP configuration across the globe, available in more than 180 countries where HP conducts business.
  • Make your workspace more workable
    Make more room with optional, versatile stands or a space-saving VESA wall mount for a range of use cases.
HP EliteOne 800 G2 - all-in-one - Core i5 6500 3.2 GHz - vPro - 8 GB - SSD 256 GB - LED 23" - UK
Personal computer - all-in-one
Platform Technology
Intel vPro Platform
Intel Core i5 (6th Gen) 6500 / 3.2 GHz (, up to 3.6 GHz, (Quad-Core)
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
6 MB
Cache Per Processor
6 MB
RAM
8 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC - PC4-17000
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
SSD 256 GB - SATA 6Gb/s
Optical Storage
DVD SuperMulti
Monitor
23" - LED - 1920 x 1080 (Full HD) - 16:9 - touchscreen
Graphics Controller
Intel HD Graphics 530 Dynamic Video Memory Technology
Audio Output
Stereo
GigE, Bluetooth, 802.11a, 802.11b/g/n
Keyboard
OS Provided
Windows 10 Pro 64-bit Edition
56.71 cm x 5.89 cm x 39.27 cm
7.34 kg
Limited warranty - parts and labour - 3 years - on-site
Platform Technology
Intel vPro Platform
Personal computer
Product Form Factor
All-in-one - with recline stand
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
CPU
Clock Speed
3.2 GHz
Max Turbo Speed
3.6 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Chipset Type
Intel Q170
Cache Memory
Installed Size
6 MB
Cache Per Processor
6 MB
RAM
Installed Size
8 GB / 32 GB (max)
Effective Memory Speed
2133 MHz
Rated Memory Speed
2133 MHz
Memory Specification Compliance
PC4-17000
SO-DIMM 260-pin
Slots
2 (Total) / 0 (empty)
Unbuffered
Configuration Features
2 x 4 GB
Hard Drive
SSD
1 x 256 GB
Interface Type
SATA 6Gb/s
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
Monitor Type
LED - IPS
Touchscreen
Yes (10-point multi-touch)
Diagonal Size
23"
Native Resolution
Widescreen Display
Image Aspect Ratio
16:9
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Colour Gamut
72%
Pixel Pitch
0.265 mm
Image Brightness
225 cd/m²
Image Contrast Ratio
1000:1
Monitor Features
Anti-glare, Projected Capacitive Touch (PCT) technology
Graphics Controller
Graphics Processor
Video Interfaces
DisplayPort
HDCP Compatible
Max Monitors Supported
3
Audio Output
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
High Definition Audio
Speakers Included
2 x right / left channel
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP Slim Wireless Business Keyboard
Wireless
Localization & Layout
Mouse
Mouse Name
HP Slim Wireless Business Mouse
Ethernet Controller
Intel I219-LM
Wireless LAN Supported
Wireless NIC
Broadcom BCM943228Z
Ethernet, Fast Ethernet, Gigabit Ethernet, Bluetooth, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11n, Skype Certified, IEEE 802.3az, IEEE 802.11ac, Bluetooth 4.1, IEEE 802.11x
Bays
1 (total) / 0 (free) x external 5.25" Slim Line , 2 (total) / 1 (free) x internal 2.5"
Slots
1 (total) / 0 (free) x CPU , 1 (total) / 0 (free) x M.2 Card (x1 mode) , 2 (total) / 0 (free) x SO-DIMM 260-pin , 1 (total) / 1 (free) x M.2 Card (x4 mode)
6 x USB 3.0 , 1 x DisplayPort , 1 x audio line-in/headphones/microphone , 1 x audio line-out/headphones , 1 x audio line-out , 1 x LAN (Gigabit Ethernet) , 1 x USB-C 3.0
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
VESA Mounting Interface
100 x 100 mm
ACPI, CCC, CECP, SEPA
Power supply
Power Provided
160 Watt
Efficiency
90%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition English
56.71 cm
5.89 cm
39.27 cm
7.34 kg
10 °C
35 °C
10 - 90% (non-condensing)
CN2X HP Care Pack Next Business Day HW Support Post Warranty Extended Service Agreement 1 Year On-Site In Stock £16.46
CN2X HP Care Pack Next Business Day HW Support Extended Service Agreement 4 Year On-Site - Desktop Only In Stock £24.77
