Elegant, sleek, user-friendly, and designed to perform, the HP EliteOne 800 is ready to deploy in demanding environments, with manageability and security, enterprise-class collaboration technologies, and touchscreen configurations.
Place it here, there, and everywhere
Deploy this redesigned, stylish All-in-One with a 58.4 cm (23") diagonal FHD display anywhere you need a powerhouse PC. Its slim design and integrated cable management make an impression at reception, on an executive’s desk or mounted on a wall.
Deeply secure
Help secure your PC with comprehensive hardware and software tools like an optional fingerprint reader and HP BIOSphere with Sure Start’s customizable BIOS-level passwords.
Power-packed performance
Drive your most demanding workloads with an All-in-One powered by fast 6th Gen Intel® Core™ processors, plus AMD Radeon™ R9 360 discrete graphics with 2 GB GDDR5 for your most challenging use cases.
Count on premier audiovisual clarity
Collaborate naturally with Cortana on Windows 10 Pro, optional 10-point capacitive touch, Audio by Bang & Olufsen, HP Clear Sound Amp, HP Noise Reduction Software, and a 2MP HD webcam.
Let nothing stand in your way
Help protect from today's security threats and maximize management and productivity features for business with Window 10 Pro. -
Ready to run, and upgrade
Make expansion and upgrades a snap with a tool-less rear access panel. -
World-class management
Simplify IT manageability with Intel vPro and Windows 10 plus HP Common Core BIOS, which enables easy management of your entire fleet of HP devices. -
Tested to go the distance
Rest easy with a PC that passed 120,000 hours of testing and is designed to undergo MIL-STD 810G testing. -
Consistently stagger deployments
Get the same HP configuration across the globe, available in more than 180 countries where HP conducts business. -
Make your workspace more workable
Make more room with optional, versatile stands or a space-saving VESA wall mount for a range of use cases.
- HP EliteOne 800 G2 - all-in-one Core i5 6500 3.2 GHz - vPro - 8 GB - SSD 256 GB - LED 23" - UK
- Personal computer - all-in-one
- Platform Technology
- Intel vPro Platform
- Localisation
- Processor
- Intel Core i5 (6th Gen) 6500 / 3.2 GHz (up to 3.6 GHz, (Quad-Core)
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 6 MB
- Cache Per Processor
- 6 MB
- RAM
- 8 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC - PC4-17000
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- SSD 256 GB - SATA 6Gb/s
- Optical Storage
- DVD SuperMulti
- Monitor
- 23" - LED - 1920 x 1080 (Full HD) - 16:9 - touchscreen
- Graphics Controller
- Intel HD Graphics 530 Dynamic Video Memory Technology
- Audio Output
- Stereo
- Networking
- 1GbE, Bluetooth, 802.11a, 802.11b/g/n
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- 56.71 cm x 5.89 cm x 39.27 cm
- 7.34 kg
- Limited warranty - parts and labour - 3 years - on-site
- Personal computer
- Product Form Factor
- All-in-one - with recline stand
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 3.2 GHz
- Max Turbo Speed
- 3.6 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- Chipset Type
- Intel Q170
Cache Memory
- Installed Size
- 6 MB
- 6 MB
RAM
- Installed Size
- Technology
- Effective Memory Speed
- 2133 MHz
- Rated Memory Speed
- 2133 MHz
- Memory Specification Compliance
- PC4-17000
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 0 (empty)
- Unbuffered
- Configuration Features
- 2 x 4 GB
Hard Drive
- SSD
- Capacity
- 1 x 256 GB
- Interface Type
- SATA 6Gb/s
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
- Monitor Type
- LED - IPS
- Touchscreen
- Yes (10-point multi-touch)
- Diagonal Size
- 23"
- Native Resolution
- Widescreen Display
- Image Aspect Ratio
- 16:9
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Colour Gamut
- 72%
- Pixel Pitch
- 0.265 mm
- Image Brightness
- 225 cd/m²
- Image Contrast Ratio
- 1000:1
- Monitor Features
- Anti-glare, Projected Capacitive Touch (PCT) technology
Graphics Controller
- Graphics Processor
- Video Interfaces
- DisplayPort
- HDCP Compatible
- Max Monitors Supported
- 3
Audio Output
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 192 kHz
- High Definition Audio
- Speakers Included
- 2 x right / left channel
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- HP Slim Wireless Business Keyboard
- Connectivity
- Wireless
- Localization & Layout
- UK
Mouse
- Mouse Name
- HP Slim Wireless Business Mouse
- Ethernet Controller
- Intel I219-LM
- Wireless LAN Supported
- Wireless NIC
- Broadcom BCM943228Z
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, Bluetooth, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11n, Skype Certified, IEEE 802.3az, IEEE 802.11ac, Bluetooth 4.1, IEEE 802.11x
- Bays
- 1 (total) / 0 (free) x external 5.25" Slim Line , 2 (total) / 1 (free) x internal 2.5"
- Slots
- 1 (total) / 0 (free) x CPU , 1 (total) / 0 (free) x M.2 Card (x1 mode) , 2 (total) / 0 (free) x SO-DIMM 260-pin , 1 (total) / 1 (free) x M.2 Card (x4 mode)
- 6 x USB 3.0 , 1 x DisplayPort , 1 x audio line-in/headphones/microphone , 1 x audio line-out/headphones , 1 x audio line-out , 1 x LAN (Gigabit Ethernet) , 1 x USB-C 3.0
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- VESA Mounting Interface
- 100 x 100 mm
- ACPI, CCC, CECP, SEPA
- Power supply
- Voltage Required
- Power Provided
- 160 watt
- Efficiency
- 90%
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Windows 10 Pro 64-bit Edition English
- 56.71 cm
- 5.89 cm
- 39.27 cm
- 7.34 kg
- 10 °C
- 35 °C
- 10 - 90% (non-condensing)
