HP EliteOne 800 G1 23" Touchscreen AIO Intel Core i5-4690S 4GB 500GB Windows 7 Professional 64-bit
Quicklinx: BC4NWS00 Mfr#: K1T32AW#ABU
  • Microsoft Windows 7 Professional 64-bit Edition
  • Core i5
  • IEEE 802.11n
Impressive performance that fits right in. The design looks amazing. Your business performance will look even better. Trust your mission-critical projects to an all-in-one PC that's built to handle the demands of virtually any business environment. Power your workday with a secure, enterprise-class PC that's easy to manage and just as reliable as it is stylish. Integrate optional touch computing in select models for a truly hands-on experience.
  • Stylish efficiency from edge to edge
    Turn the front room into the showroom, and optimize the space of your back room as well. With slim, sleek glass across a 23-inch diagonal screen, this all-in-one PC impresses virtually anywhere.Stay organized and free up more room for work. This space-saving all-in-one has several stand options, and easily mounts on the wall.
  • Fast-track your performance
    Quickly open new files and switch applications with less wait time thanks to solid-state drives and solid-state hybrid drive options. Get the latest processing technology with a choice of 4th generation Intel Core processors.Watch your inbox while working on other tasks. Connect up to four displays, using the digital DisplayPort with multi-stream and optional discrete graphics card.Intel Smart Response Technology (SRT), a disk cache solution, delivers similar performance associated with Solid State Drives while retaining the data storage capacity of today's large Hard Disk Drives.Make the most of virtual conferencing. Bring work to life through rich sound and video using DTS Studio Sound and an HD webcam.
  • Experience the simplicity of touch in select models
    Delight users with the intuitive control of an optional 10-point capacitive touchscreen that makes the most of Windows 8. Rotation sensors let you see what's on screen as it was meant to be displayed by rotating from landscape to portrait.
  • The hub of your mobile world
    Speed up charging with a fast charging USB port. The nearly 2.8x stronger charging current helps compatible devices charge faster than standard USB 3.0 ports.Easily share your internet connection with your devices and help colleagues get online fast with HP Wireless Hotspot.Maintain tighter control over device security. Use the optional integrated near-field communications (NFC) capabilities to support custom applications such as advanced user authentication.
  • Heavy security, efficiently managed, reliability for the long haul
    Keep it secure, keep it simple. IT efficiency reigns supreme when it's backed by a full portfolio of HP Client Security and Intel vPro management features.Save your data. RAID configurations utilize dual storage drives to automatically back up and help protect your sensitive data.Count on the support you need to get long-term value out of your investment. This work-ready PC is designed for a long lifecycle, with platform stability up to 30 months.Rest assured. Talk to an agent any time and get priority service at any HP repair center with HP Elite Premium Support, at no additional charge.HP EliteOne PCs are rigorously tested to help ensure reliability. During the HP Total Test Process, our PCs experience 115,000 hours of performance trials to help get you through your business day.
HP EliteOne 800 G1 - all-in-one - Core i5 4690S 3.2 GHz - vPro - 4 GB - HDD 500 GB - LED 23" - UK - TAA Compliant
Personal computer - all-in-one - administrator password, power-on password, USB port control, chassis intrusion detection, tilt adjustment, swivel adjustment, HP Disk Sanitizer, adjustable height, HP File Sanitizer, HP BIOS Protection
Platform Technology
Intel vPro Platform
Intel Core i5 (4th Gen) 4690S / 3.2 GHz (, up to 3.9 GHz, (Quad-Core)
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
6 MB
Cache Per Processor
6 MB
RAM
4 GB (installed) / 16 GB (max) - DDR3 SDRAM - non-ECC - PC3-12800
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
HDD 500 GB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD SuperMulti
Monitor
23" - LED - 1920 x 1080 (Full HD) - 16:9 - Multi-Touch
Graphics Controller
Intel HD Graphics 4600 Dynamic Video Memory Technology
Audio Output
Stereo - integrated
GigE, 802.11a, 802.11b/g/n
Keyboard
AC 120/230 V
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 8.1 Pro) + Windows 8.1 Pro Licence
Software Included
CyberLink Power2Go, Adobe Flash Player, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP Support Assistant, HP ePrint, CyberLink PowerDVD BD Edition, Foxit PhantomPDF Express, Device Access Manager, HP Client Security, HP PageLift, HP File Sanitizer, Drive Encryption, Box.net, HP Disk Sanitizer External Edition (free download)
56 cm x 19.48 cm x 52.89 cm
15.17 kg
TAA Compliant
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years - on-site
Platform Technology
Intel vPro Platform
Personal computer
Recommended Use
Small business, corporate business
Product Form Factor
All-in-one
Built-in Devices
Stereo speakers
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
CPU
Clock Speed
3.2 GHz
Max Turbo Speed
3.9 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Chipset Type
Intel Q87
Cache Memory
Installed Size
6 MB
Cache Per Processor
6 MB
RAM
Installed Size
4 GB / 16 GB (max)
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
SO-DIMM 204-pin
Slots
2 (Total) / 1 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA - integrated
Controller Interface Type
SATA 6Gb/s
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
Monitor Type
LED - IPS - Multi-Touch
Diagonal Size
23"
Native Resolution
Widescreen Display
Image Aspect Ratio
16:9
Horizontal Viewing Angle
179
Vertical Viewing Angle
179
Colour Gamut
72%
Pixel Pitch
0.256 mm
Image Brightness
225 cd/m²
Image Contrast Ratio
1000:1
Monitor Features
Anti-glare, 10-point multi-touch
Graphics Controller
Integrated
Graphics Processor
Video Interfaces
DisplayPort
HDCP Compatible
Max Monitors Supported
3
Audio Output
Integrated
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
High Definition Audio, DTS Studio Sound
Speakers Included
2 x right / left channel
Camera
Integrated
Resolution (MP)
2 Megapixel
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP Standard Keyboard
PS/2
Localization & Layout
Mouse
PS/2
Audio Input
Stereo microphone
Ethernet Controller
Intel I217-LM
Wireless LAN Supported
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Remote Management Protocol
ASF 2.0
Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1as, IEEE 802.11n, IEEE 802.3az
Bays
1 (total) / 0 (free) x external 5.25" Slim Line , 2 (total) / 1 (free) x internal 2.5"
Slots
1 (total) / 0 (free) x CPU , 1 (total) / 1 (free) x MXM 3.0 Type A , 1 (total) / 0 (free) x PCIe Half Mini Card , 2 (total) / 1 (free) x SO-DIMM 204-pin , 1 (total) / 1 (free) x mSATA
6 x USB 3.0 , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x microphone , 1 x headphones , 1 x serial , 1 x audio line-out , 1 x LAN (Gigabit Ethernet) , 1 x DisplayPort
Administrator password, power-on password, USB port control, chassis intrusion detection, tilt adjustment, swivel adjustment, HP Disk Sanitizer, adjustable height, HP File Sanitizer, HP BIOS Protection
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
ACPI, CSA, UL, CCC, FCC, RoHS, Energy-using Products (EuP) Lot 6, WEEE, CECP
TAA Compliant
Power supply
AC 120/230 V
Power Provided
200 Watt
80 PLUS Certification
80 PLUS
Efficiency
93%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro) + Windows 8.1 Pro Licence - English
Software
Sustainability Information
ENERGY STAR Certified
56 cm
19.48 cm
52.89 cm
15.17 kg
10 °C
35 °C
10 - 90% (non-condensing)
