HP EliteOne 705 G1 23" AIO AMD A8 PRO-7600 4GB 500GB Windows 7 Professional 64-bit
Quicklinx: BC3HWS00 Mfr#: J4V28EA#ABU
  • Microsoft Windows 7 Professional 64-bit Edition
  • AMD Radeon R7
The design looks amazing. Your business performance will look even better. Trust your mission critical projects to an all-in-one PC that's built to handle the demands of virtually any business environment. Power your workday with a secure PC that's as reliable as it is stylish.
HP EliteOne 705 G1 - all-in-one - A8 PRO-7600B 3.1 GHz - 4 GB - HDD 500 GB - LED 23" - TAA Compliant
Personal computer - all-in-one - administrator password, power-on password, USB port control, chassis intrusion detection, tilt adjustment, swivel adjustment, lockable rear panel, HP BIOS Protection
AMD A8 PRO-7600B / 3.1 GHz (, up to 3.8 GHz, (Quad-Core)
Cache Memory
4 MB L2 Cache
Cache Per Processor
4 MB
RAM
4 GB (installed) / 16 GB (max) - DDR3 SDRAM - non-ECC - PC3-12800
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
HDD 500 GB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD SuperMulti
Card Reader
5 in 1
Monitor
23" - LED - 1920 x 1080 (Full HD) - 16:9
Graphics Controller
AMD Radeon R7
Audio Output
Stereo - integrated
GigE
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 8.1 Pro) + Windows 8.1 Pro Licence
Software Included
Cyberlink PowerDVD, CyberLink Power2Go, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP Recovery Manager, HP Support Assistant, HP ePrint, CyberLink YouCam BE, Foxit PhantomPDF Express, HP Spare Key, HP Client Security, Device Access Manager with Just In Time Authentication, HP PageLift, HP File Sanitizer, Box.net 50GB storage, Drive Encryption, HP Manageability, HP Disk Sanitizer External Edition (free download)
56 cm x 15.34 cm x 43.72 cm
10.06 kg
TAA Compliant
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years - on-site
Personal computer
Recommended Use
Small business, corporate business
Product Form Factor
All-in-one
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
CPU
AMD A8 PRO-7600B
Clock Speed
3.1 GHz
Max Turbo Speed
3.8 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Chipset Type
AMD D4
Cache Memory
Installed Size
L2 Cache - 4 MB
Cache Per Processor
4 MB
RAM
Installed Size
4 GB / 16 GB (max)
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
SO-DIMM 204-pin
Slots
2 (Total) / 1 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA - integrated
Controller Interface Type
SATA 6Gb/s
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Card Reader
5 in 1 card reader
Supported Flash Memory Cards
SD Memory Card, SDHC Memory Card, SDXC Memory Card, SDHC UHS-I Memory Card, SDXC UHS-I Memory Card, SDHC UHS-II Memory Card, SDXC UHS-II Memory Card
Monitor
Monitor Type
LED - IPS
Diagonal Size
23"
Native Resolution
Widescreen Display
Image Aspect Ratio
16:9
Horizontal Viewing Angle
179
Vertical Viewing Angle
179
Pixel Pitch
0.256 mm
Image Brightness
250 cd/m²
Image Contrast Ratio
1000:1
Monitor Features
Anti-glare
Graphics Controller
Integrated
Graphics Processor
AMD Radeon R7
Total Available Graphics Memory
1.8 GB
Video Interfaces
DisplayPort
Max Monitors Supported
4
Audio Output
Integrated
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
High Definition Audio, DTS Studio Sound
Speakers Included
2 x right / left channel
Camera
Integrated
Resolution (MP)
2 Megapixel
Audio Input
Stereo microphone
Integrated
Ethernet Controller
Broadcom BCM5762
Remote Management Protocol
ASF 2.0
Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.1x, IEEE 802.1as, IEEE 802.3az
Bays
1 (total) / 0 (free) x external 5.25" Slim Line , 2 (total) / 1 (free) x internal 2.5"
Slots
1 (total) / 0 (free) x CPU , 1 (total) / 1 (free) x PCIe Half Mini Card , 2 (total) / 1 (free) x SO-DIMM 204-pin , 1 (total) / 1 (free) x M.2 Card
4 x USB 3.0 , 2 x USB 2.0 , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x microphone , 1 x headphones , 1 x serial , 1 x audio line-out , 1 x LAN (Gigabit Ethernet) , 1 x DisplayPort
Administrator password, power-on password, USB port control, chassis intrusion detection, tilt adjustment, swivel adjustment, lockable rear panel, HP BIOS Protection
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
VESA Mounting Interface
100 x 100 mm
ACPI, CSA, UL, CCC, FCC, Energy-using Products (EuP) Lot 6, CECP, SEPA
TAA Compliant
Power supply
Power Provided
200 Watt
80 PLUS Certification
80 PLUS
Efficiency
93%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro) + Windows 8.1 Pro Licence
Software
Sustainability Information
ENERGY STAR Certified
56 cm
15.34 cm
43.72 cm
10.06 kg
10 °C
35 °C
10 - 90% (non-condensing)
