HP EliteOne 1000 G1 Core i7-7700 8GB 256GB SSD 27" Win 10 Pro All-in-one
Quicklinx: DC5KWS00 Mfr#: 2LU00EA#ABU
  • Core i7
Meetings come to life on your choice of AiO displays that transform your workspace into a rich video conferencing solution with immersive video and audio engagement, capacitive touch controls, and a built-in pop-up privacy camera.
  • Let nothing stand in your way
    Super-charge your HP PC with Windows 10 Pro and a 7th Gen Intel Core processor with optional Intel Optane memory.
  • Choose from three optional display sizes
    Pick the right display to suit your needs. Choose from a touch or non-touch 23.8-inch diagonal, 27-inch diagonal non-touch, and a 34-inch diagonal non-touch curved display for an immersive and engaging visual experience.
  • The adaptable all-in-one
    With core computing components like 7th Gen Intel Core i3/i5/i7 processors located in the base of our most serviceable AiO, you can upgrade or redeploy displays as user and business needs change over time.
  • Give your speakers a boost
    HP Audio Boost balances loudness and clarity, and enhances bass for improved speech quality.
  • Cut out the chatter
    Suppress background noise including keyboard clicks with HP Noise Cancellation.
  • Browse confidently
    HP Sure Click provides hardware-enforced security for web browsers, protecting your PC from websites infected with malware, ransomware or viruses.
HP EliteOne 1000 G1 - all-in-one - Core i7 7700 3.6 GHz - 8 GB - SSD 256 GB - LED 27"
Personal computer - all-in-one
Intel Core i7 (7th Gen) 7700 / 3.6 GHz (, up to 4.2 GHz, (Quad-Core)
Processor Socket
LGA1151 Socket
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2, Intel Smart Cache
Cache Memory
8 MB
Cache Per Processor
8 MB
RAM
8 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
SSD 256 GB - PCI Express - M.2 2280 - NVM Express (NVMe)
Optical Storage
No optical drive
Monitor
27" - LED - 3840 x 2160 (Ultra HD 4K) - 16:9
Graphics Controller
Intel HD Graphics 630
Camera
Audio Output
Stereo
1GbE
OS Provided
Windows 10 Pro 64-bit Edition
61.33 cm x 19 cm x 45.73 cm
10.2 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years
Personal computer
Product Form Factor
All-in-one
Built-in Devices
Fingerprint reader
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Clock Speed
3.6 GHz
Max Turbo Speed
4.2 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA1151 Socket
Chipset Type
Intel Q270
Cache Memory
Installed Size
8 MB
Cache Per Processor
8 MB
RAM
Installed Size
8 GB / 32 GB (max)
Effective Memory Speed
2400 MHz
Rated Memory Speed
2400 MHz
SO-DIMM 260-pin
Slots
2 (Total) / 1 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
1 x 8 GB
Hard Drive
SSD - M.2 2280
1 x 256 GB
Interface Type
PCI Express
NVM Express (NVMe)
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
No optical drive
Monitor
Monitor Type
LED - IPS
Diagonal Size
27"
Native Resolution
Widescreen Display
Image Aspect Ratio
16:9
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Colour Gamut
99% sRGB
Pixel Pitch
0.1554 mm
Image Brightness
350 cd/m²
Image Contrast Ratio
1000:1
Monitor Features
Ultra HD 4K anti-glare, 99% sRGB colour gamut
Graphics Controller
Graphics Processor
Video Interfaces
HDMI, DisplayPort
Audio Output
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
High Definition Audio
Speakers Included
2 x right / left channel
Camera
Camera
Resolution (MP)
2 Megapixel (rear), 2 Megapixel (front)
Resolution
Full HD
IR camera, Windows Hello
Audio Input
Dual array microphone
Ethernet Controller
Intel I219-LM
Bays
1 (total) / 1 (free) x internal 2.5" x 1/8H
Slots
1 (total) / 1 (free) x M.2 Card - 2230 , 1 (total) / 0 (free) x M.2 Card - 2280
5 x USB 3.1 Gen 1 (two of them with wake functionality, one of them is charging) , 1 x DisplayPort input , 1 x DisplayPort output , 1 x HDMI output , 1 x LAN (Gigabit Ethernet) , 1 x headphones , 1 x USB 3.1 - Type C
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
Power Provided
180 Watt
Efficiency
87%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition English
Sustainability Information
ENERGY STAR Certified
61.33 cm
19 cm
45.73 cm
10.2 kg
10 °C
50 °C
10 - 95% (non-condensing)
DC5K HP Care Pack Next Business Day HW Support Post Warranty Extended Service Agreement 1 Year On-Site In Stock £27.34
DC5K HPE DisplayPort DVI-D Adapter In Stock £19.77
DC5K HPE USB to Serial Port Adapter In Stock £23.07
