HP EliteDisplay S240uj 2560 x 1440 23.8" 5ms HDMI DP USB IPS Monitor
Quicklinx: CH3RWS00 Mfr#: T7B66AA#ABU
Move into the workspace of the future with the HP EliteDisplay S240uj monitor, display with fully integrated wireless charging, and USB-C. It has premium Audio by Bang & Olufsen and QHD and looks cool from every angle with just two cables on the desk.
  • Ready for the perfect partner
    Streamline your workspace when you pair the display with your HP Elite Slice, HP x2 1012, HP EliteBook Folio, HP Chromebook 13, or HP Elite x3 and send video to and get power from the display with just one USB-C connection.
  • Even more connections for everything you use
    Show your old school devices some love with DisplayPort 1.2, HDMI/MHL, Video/Audio/HDCP, and USB 3.0 for data.
  • Divide and conquer
    Design the screen for how you work with HP Display Assistant software, which enables screen partitioning and helps deter theft by deactivating a monitor that's disconnected without approval.
HP EliteDisplay S240uj Wireless Charging Monitor - LED monitor - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class C
Energy Consumption per Year
64 kWh
Power Consumption (On mode)
42 W
Wireless charger, USB 3.0/USB-C hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
2560 x 1440 at 60 Hz
Pixel Pitch
0.20535 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
72%
Input Connectors
HDMI, HDMI (MHL), DisplayPort, USB-C
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, anti-static
Voltage
AC 120/230 V
Silver
54.06 cm x 21.34 cm x 42.9 cm
5.5 kg
English / United Kingdom
Plug and Play, CSA, VCCI, BSMI, TUV S, WHQL, CB, CCC, FCC, ISO 9241-307, WEEE, ICES, MEPS, TUV Bauart, China Energy Label Level 1, CECP, CEL, EAC, ISC, RCM, MSIP, SEPA, CoC, low halogen
5-year warranty
Display Type
Energy Class
Class C
64 kWh
Diagonal Size
23.8"
Built-in Devices
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.20535 mm
Pixel Per Inch
124
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72%
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
24 - 75 Hz
Horizontal Refresh Rate
24 - 90 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
HDCP, Bang & Olufsen audio
Silver
54.06 cm x 21.34 cm x 42.9 cm - with stand
5.5 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
MHL / HDMI , DisplayPort , USB-C/DisplayPort 1.2 Alt Mode , USB-C upstream , USB 3.0 upstream , 2 x USB 3.0 downstream , Headphones , HDMI
Mechanical
Tilt
Tilt Angle
-5/+21
1 x Mobile High-Definition Link (MHL) cable , 1 x HDMI cable , 1 x DisplayPort cable , 1 x USB cable , 1 x USB-C cable
Backlight Life
30,000 hours
Input Voltage
AC 120/230 V
42 W
Power Consumption (Typical)
40 Watt
Power Consumption Stand by
0.5 Watt
Windows 10
Dimensions & Weight Details
With stand - width: 54.06 cm - depth: 21.34 cm - height: 42.9 cm - weight: 5.5 kg , Without stand - width: 54.06 cm - depth: 4.43 cm - height: 34.6 cm - weight: 3.8 kg
Limited warranty - 5 years - on-site - response time: next business day
5 °C
35 °C
20 - 80% (non-condensing)
CH3R HP Care Pack Next Business Day Hardware Support Extended Service Agreement 1 Year On-Site In Stock £5.89
