Create a dual-display mobile workspace almost anywhere with the HP EliteDisplay S140u 35.56 cm (14") USB Portable Monitor, an ultra-compact, strikingly thin, high-resolution display in a wraparound cover. Fold it back to add a second screen for your Windows tablet or notebook and connect with one USB cable.
Sleek, stylish, and ultra-portable.
The super-compact, ultra-thin design weighs 1.44 Kilograms, and is just 1.27 centimeters thick. The cover doubles as an adjustable stand and helps protect the display so you can slide it into your carrying case with your tablet or notebook.
Double your visual workspace.
Pair the 1600 x 900 high-resolution display with a notebook or tablet to extend to a dual-display setup wherever you work, or make a big impression with mirror mode.
Super simple set-up.
Get ready in a snap with the single USB cable that also acts as a power source. Fold back the cover and connect to any USB port on your notebook or tablet and you’re ready to work.
                Designed with the environment in mindBe a better consumer with a display that has environmentally responsible components that include low halogen, arsenic-free glass, and mercury-free backlights.
- HP EliteDisplay S140u - LED monitor - 14"
- LED-backlit LCD monitor - 14"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- 1600 x 900 at 60 Hz
- Pixel Pitch
- 0.1935 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- 400:1
- Response Time
- 8 ms (grey-to-grey)
- Colour Support
- 262,144 colours
- Colour Gamut
- 72%
- Input Connectors
- USB
- Screen Coating
- Anti-glare
- Black
- Dimensions (WxDxH) - without stand
- 34.58 cm x 1.35 cm x 21.71 cm
- 1.2 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, CSA, UL, VCCI, BSMI, cUL, VESA EDID, CB, CCC, FCC, C-ETL, RoHS, IEC 60950-1, KCC, ICES, S Mark, TUV Bauart, GOST-R 50377-1992, GOST 25861-83, NOM-019-SCFI-1998, ISC, RCM, ISO9241-307
- 3-year warranty
- Display Type
- Diagonal Size
- 14"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.1935 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- 400:1
- Colour Support
- 262,144 colours
- Colour Gamut
- 72%
- Response Time
- Video Bandwidth
- 108 MHz
- Horizontal Viewing Angle
- 90
- Vertical Viewing Angle
- 50
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Colour Temperature
- 6500K
- Controls & Adjustments
- Brightness
- On-screen Digital Controls
- Black
- 34.58 cm x 1.35 cm x 21.71 cm - without stand
- 1.2 kg
- USB 3.0
- VESA interface support, programmable
- Cables Included
- 1 x micro-USB 3.0 to USB 3.0 / USB 2.0 cable - 1 m
- Backlight Life
- 15,000 hours
- Power Consumption (Typical)
- 7 Watt
- Power Consumption Stand by
- 0.8 Watt
- OS Required
- Microsoft Windows 7 Professional (32/64 bits), Windows 8.1 (32/64 bits), Windows 8.1 Pro (32/64 bits)
- Dimensions & Weight Details
- Without stand - width: 34.58 cm - depth: 1.35 cm - height: 21.71 cm - weight: 1.2 kg , With stand - width: 34.58 cm - depth: 1.6 cm - height: 22.1 cm - weight: 1.49 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - parts and labour - 3 years
- 5 °C
- 35 °C
- 20 - 70% (non-condensing)
