Unfold dual-display productivity anywhere you work-on your own, in groups or at client sites-with the HP EliteDisplay S14 USB Portable Monitor, HP's first portable 35.56 cm (14") USB-C display. Fold back the wraparound easel cover, stand up, and connect to your device with just one USB-C cable.
Perfectly portable
Maximize your productivity and lighten your load with a Full HD display that weighs 1 kg and is less than 9 mm thick, so you can tuck it into your carrying case alongside your device without weighing you down. -
Easy USB-C efficiency
Set up quickly with just one USB-C cable that transfers video and pulls power from your notebook or tablet - no power cable required. -
Customize your settings
Control brightness, contrast, and response time, and activate HP Low Blue Light mode to filter blue light emission and shift colors to a warmer spectrum for more comfortable viewing, all from the intuitive OSD.
- HP EliteDisplay S14 - LED monitor - Full HD (1080p) - 14"
- LED-backlit LCD monitor - 14"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.1611 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- 700:1 / 5000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 262,144 colours
- Input Connectors
- USB-C
- Screen Coating
- Anti-glare
- Ebony black
- Dimensions (WxDxH) - without stand
- 32.78 cm x 0.86 cm x 20.95 cm
- 1 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, CSA, UL, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, ICES, MEPS, KC, CECP, CEL, EAC, ISC, low halogen
- Display Type
- Diagonal Size
- 14"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.1611 mm
- Pixel Per Inch
- 157
- Brightness
- 200 cd/m²
- Contrast Ratio
- Colour Support
- 262,144 colours
- Response Time
- Vertical Refresh Rate
- 60 Hz
- Horizontal Refresh Rate
- 80 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
- 45% NTSC colour gamut, Mercury free, arsenic-free glass
- Ebony black
- 32.78 cm x 0.86 cm x 20.95 cm - without stand
- 1 kg
- USB-C
- Cables Included
- 1 x USB-C cable - 1.8 m
- Backlight Life
- 15,000 hours
- 5 Watt
- Power Consumption Stand by
- 0.3 Watt
- Included Software
- HP Display Assistant
- OS Required
- Microsoft Windows 7, Windows 8, Windows 10
- Shipping Width
- 39.4 cm
- Shipping Depth
- 6.3 cm
- Shipping Height
- 28.4 cm
- Shipping Weight
- 1.9 kg
- ENERGY STAR Certified
- ENERGY STAR Version
- 7.0
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
