HP EliteDisplay E324q 32" 2560x1440 7ms HDMI DisplayPort LED Monitor
Quicklinx: FBQNWS00 Mfr#: 5DP31AT#ABU
Astound your open office with the mammoth HP EliteDisplay E324q 31.5-inch QHD Monitor that has plenty of screen space without overwhelming your desk. Get broad device compatibility with ports that include USB-C for easy pairing with a range of HP PCs.
  • Put all your projects onscreen
    Display more of your data at the same time in Quad HD 2560 x 1440 resolution on a massive 31.5" diagonal screen. No more toggling between open windows or paging up and down. And the stunningly thin design enhances your modern aesthetic.
  • Comfortable from every angle
    Minimize your line-of-sight disruptions and see more of your screen with the 3-sided micro-edge bezel. Find your sweet spot with adjustable tilt, height, and swivel settings. Customize portrait or landscape views with built-in pivot rotation.
  • Save precious workspace
    Streamline your desk by installing your HP Desktop Mini, HP Chromebox or select HP Thin Client behind the screen, directly on the column stand.
HP EliteDisplay E324q - LED monitor - 31.5" - Smart Buy
LED-backlit LCD monitor - 31.5"
Energy Class
Class F
Power Consumption (On mode)
30.4 W
USB 3.1 hub
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 60 Hz
Pixel Pitch
0.272 mm
Brightness
350 cd/m²
Contrast Ratio
3000:1 / 10000000:1 (dynamic)
Response Time
7 ms (grey-to-grey)
Input Connectors
HDMI, DisplayPort, USB-C
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
71.4 cm x 24.04 cm x 43.94 cm
10.3 kg
English / United Kingdom
Manufacturer Selling Program
HP Smart Buy
Plug and Play, TUV GS, VCCI, BSMI, CB, CCC, FCC, KCC, ICES, S Mark, cTUVus, MEPS, E-Standby, CEC, KC, CECP, CEL, ISC, RCM, SEPA, BIS, low halogen, CE/EMC, TUV LBL, IEC 62368
Display Type
Energy Class
Class F
Diagonal Size
31.5"
Built-in Devices
USB 3.1 hub
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.272 mm
Brightness
350 cd/m²
Contrast Ratio
Response Time
7 ms (grey-to-grey)
Vertical Refresh Rate
60 Hz
Horizontal Refresh Rate
90 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Mercury free, arsenic free
71.4 cm x 24.04 cm x 43.94 cm - with stand
10.3 kg
USB 3.1 upstream , 4 x USB 3.1 downstream , HDMI (HDCP) , DisplayPort (HDCP) , USB-C with Power Delivery
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
VESA
1 x HDMI cable , 1 x DisplayPort cable , 1 x USB-C cable , 1 x USB-A to USB-B cable
HP Smart Buy
Security Slot Type
Kensington security slot
Input Voltage
30.4 W
30.4 kWh/1000h
Power Consumption (Typical)
55 Watt
Power Consumption Stand by
0.3 Watt
Included Software
HP Display Assistant
Dimensions & Weight Details
Without stand - width: 71.4 cm - depth: 4.75 cm - height: 41.94 cm
Shipping Width
82.8 cm
Shipping Depth
52.8 cm
Shipping Height
22.8 cm
Shipping Weight
16.1 kg
5 °C
35 °C
20 - 80% (non-condensing)
