Connect and collaborate in complete comfort on the HP EliteDisplay E273m 68.58 cm (27") Monitor, which is Skype for Business certified for optimal video and audio experiences between displays and has a 3-sided micro-edge bezel for seamless multi-display tiling and 4-way adjustable ergonomics.
Customizable collaboration
Personalize your setup by combining your display with an HP accessory designed for UCC, including wired and wireless headsets, a speaker phone, and keyboards with dedicated collaboration keys. -
Adaptable for a single-footprint setup
Mount your compatible HP Desktop Mini PC or select Thin Client or Chromebox directly on the column stand using the optional HP B300 PC Mounting Bracket. -
Expanded, flexible connectivity
Keep your workspace clean with single-cable video and data over USB-C ; be ready for multi-generation products with DisplayPort , HDMI, VGA, and a 3-port USB hub. -
Be responsible
Reduce power consumption and help lower costs with a low halogen, ENERGY STAR certified, EPEAT 2019 registered display that meets TCO Certified Edge with 85% Post-Consumer Recycled plastics. -
Divide and conquer
Design the screen for how you work with HP Display Assistant software, which enables screen partitioning and helps deter theft by dimming a display that's disconnected without approval.
- HP EliteDisplay E273m - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class F
- Energy Consumption per Year
- 37 kWh
- Power Consumption (On mode)
- 25 W
- Camera, 2 microphones, USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.311 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 5 ms (On/Off)
- Input Connectors
- HDMI, VGA, DisplayPort, USB-C
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, anti-static
- Voltage
- AC 120/230 V (50/60 Hz)
- 61 cm x 21.4 cm x 38.4 cm
- 7.9 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, VCCI, BSMI, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, WEEE, cTUVus, MEPS, CECP, CEL, EAC, ISC, MSIP, CoC, low halogen, ICE
- 5-year warranty
- Display Type
- Energy Class
- Class F
- 37 kWh
- Diagonal Size
- 27"
- Built-in Devices
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.311 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Response Time
- 5 ms (On/Off)
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- HDCP, Mercury free, arsenic-free glass, Micro Edge
- 61 cm x 21.4 cm x 38.4 cm - with stand
- 7.9 kg
- HDMI (HDCP) , DisplayPort (HDCP) , VGA , USB-C upstream , 2 x USB 3.0
Mechanical
- Tilt Angle
- -5/+22
- Swivel Angle
- 45
- Rotation Angle
- 90
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- 25 W
- Power Consumption SDR (On mode)
- 23 kWh/1000h
- Power Consumption (Typical)
- 32 Watt
- Power Consumption Stand by
- 0.5 Watt
- On / Off Switch
- Dimensions & Weight Details
- With stand - width: 61 cm - depth: 21.4 cm - height: 38.4 cm - weight: 7.9 kg , Without stand - width: 61 cm - depth: 4.75 cm - height: 38.9 cm
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 5 years - on-site - response time: next business day
- 5 °C
- 35 °C
- 20 - 80%
