HP EliteDisplay E273m 27" 1920x1080 5ms VGA HDMI DisplayPort USB-C IPS LED Monitor
Quicklinx: DZRFWS00 Mfr#: 1FH51AA#ABU
Connect and collaborate in complete comfort on the HP EliteDisplay E273m 68.58 cm (27") Monitor, which is Skype for Business certified for optimal video and audio experiences between displays and has a 3-sided micro-edge bezel for seamless multi-display tiling and 4-way adjustable ergonomics.
  • Customizable collaboration
    Personalize your setup by combining your display with an HP accessory designed for UCC, including wired and wireless headsets, a speaker phone, and keyboards with dedicated collaboration keys.
  • Adaptable for a single-footprint setup
    Mount your compatible HP Desktop Mini PC or select Thin Client or Chromebox directly on the column stand using the optional HP B300 PC Mounting Bracket.
  • Expanded, flexible connectivity
    Keep your workspace clean with single-cable video and data over USB-C ; be ready for multi-generation products with DisplayPort , HDMI, VGA, and a 3-port USB hub.
  • Be responsible
    Reduce power consumption and help lower costs with a low halogen, ENERGY STAR certified, EPEAT 2019 registered display that meets TCO Certified Edge with 85% Post-Consumer Recycled plastics.
  • Divide and conquer
    Design the screen for how you work with HP Display Assistant software, which enables screen partitioning and helps deter theft by dimming a display that's disconnected without approval.
HP EliteDisplay E273m - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class F
Energy Consumption per Year
37 kWh
Power Consumption (On mode)
25 W
Camera, 2 microphones, USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms (On/Off)
Input Connectors
HDMI, VGA, DisplayPort, USB-C
Display Position Adjustments
Screen Coating
Anti-glare, anti-static
Voltage
61 cm x 21.4 cm x 38.4 cm
7.9 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
Plug and Play, VCCI, BSMI, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, WEEE, cTUVus, MEPS, CECP, CEL, EAC, ISC, MSIP, CoC, low halogen, ICE
5-year warranty
Display Type
Energy Class
Class F
37 kWh
Diagonal Size
27"
Built-in Devices
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
250 cd/m²
Contrast Ratio
Response Time
5 ms (On/Off)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
HDCP, Mercury free, arsenic-free glass, Micro Edge
61 cm x 21.4 cm x 38.4 cm - with stand
7.9 kg
HDMI (HDCP) , DisplayPort (HDCP) , VGA , USB-C upstream , 2 x USB 3.0
Mechanical
Tilt Angle
-5/+22
Swivel Angle
45
Rotation Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security Slot Type
Kensington security slot
Input Voltage
25 W
23 kWh/1000h
Power Consumption (Typical)
32 Watt
Power Consumption Stand by
0.5 Watt
On / Off Switch
Dimensions & Weight Details
With stand - width: 61 cm - depth: 21.4 cm - height: 38.4 cm - weight: 7.9 kg , Without stand - width: 61 cm - depth: 4.75 cm - height: 38.9 cm
Sustainability Information
ENERGY STAR Certified
Limited warranty - 5 years - on-site - response time: next business day
5 °C
35 °C
20 - 80%
DZRF HP Care Pack Next Business Day Hardware Support Extended Service Agreement 4 Years On-Site In Stock £22.36
DZRF HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site In Stock £32.96
DZRF HP Care Pack Next Business Day Hardware Support Extended Service Agreement 1 Year On-Site In Stock £5.89
DZRF HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Yrs On-Site for Monitor In Stock £10.59
