HP EliteDisplay E273d 27" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor
Quicklinx: FBQMWS00 Mfr#: 5WN63AT#ABU
Diagonal Size: 27in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: None
Interfaces: VGA (HD-15), DisplayPort, USB-C, HDMI
£451.00 ex VAT
£541.20 inc VAT
Streamlined connectivity, big-screen display, cleaner ocean.
Simplify your desk and get room to work with the HP EliteDisplay E273d 27-inch Docking Monitor. Set up your devices and network one time and connect a notebook through USB-C™ or USB-A. Help prevent ocean waste with a display created with the equivalent of more than three plastic water bottles.
  • Create a space for your entire notebook fleet to touch down immediately through USB-C™ or USB-A, access devices and a wired network, and even power your PC through USB-C™.
  • Be a better global citizen with our first display manufactured with ocean-bound plastics to help reduce waterway pollution. We go one step further with 100% fiber recyclable packaging
  • Quickly videoconference with the integrated, high-resolution, pop-up webcam that retracts into the bezel when not in use. Conveniently join web calls by connecting your headset at the display.
  • Command your workspace from one connection
    Create a space for your entire notebook fleet to touch down immediately through USB-C or USB-A and access devices and a wired network. This docking display will even power your PC through USB-C .
  • Expand your view
    Add a second display daisy-chained through your PC's USB-C connection. 3-sided micro-edge bezels ensure a virtually seamless view on one or dual displays.
  • The docking display you can feel good about
    Be a better global citizen with our first display manufactured with ocean-bound plastics to help reduce waterway pollution. We go one step further with 100% fiber recyclable packaging.
HP EliteDisplay E273d Docking Monitor - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
720p webcam, dual array microphone, USB 3.1 Gen 1/USB-C hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Input Connectors
HDMI, VGA, DisplayPort, USB-C
Screen Coating
Anti-glare
61.09 cm x 4.63 cm x 36.3 cm
English / United Kingdom
Plug and Play, TUV GS, VCCI, BSMI, NOM, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, MEPS, CEL, EAC, ISC, low halogen, Mercury-free
5-year warranty
Display Type
Diagonal Size
27"
Viewable Size
27"
Built-in Devices
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
250 cd/m²
Contrast Ratio
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
60 Hz
Horizontal Refresh Rate
80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Bezel Type
Flat front
HDCP, On-screen Digital Controls, arsenic-free glass, DisplayLink Technology
61.09 cm x 4.63 cm x 36.3 cm - without stand
HDMI (HDCP) , USB-C upstream/DisplayPort with Power Delivery , VGA , USB , 4 x USB 3.1 downstream with Battery Charging , Audio line-in/out , Audio line-in , Network (RJ-45) , DisplayPort output
Security lock slot (cable lock sold separately), detachable stand, VESA interface support
1 x USB cable , 1 x USB-C cable
Security Slot Type
Kensington security slot
40 Watt
Power Consumption (Typical)
40 Watt
Power Consumption Stand by
0.5 Watt
Included Software
HP Display Assistant, CyberLink Youcam
Dimensions & Weight Details
With stand - width: 61.09 cm - depth: 21.4 cm - height: 50.85 cm - weight: 7.52 kg
Shipping Width
73.2 cm
Shipping Depth
28.2 cm
Shipping Height
44.6 cm
Limited warranty - parts and labour - 5 years - on-site
5 °C
35 °C
20 - 80% (non-condensing)
Diagonal Size: 27in
Response Time: 5ms
Speakers: None
Interfaces: DisplayPort
Interfaces: USB-C
Interfaces: HDMI
Brand: HP
