HP EliteDisplay E273 27" 1920x1080 5ms VGA HDMI LED Monitor
Quicklinx: DMXPWS00 Mfr#: 1FH50AT#ABU
Diagonal Size: 27in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: None
Interfaces: DisplayPort, HDMI, VGA (HD-15)
£177.07 ex VAT
£212.48 inc VAT
Style meets substance in a strikingly modern business display crafted for optimal viewing, productivity, and ergonomics. The HP EliteDisplay E273 68.58 cm (27") Monitor has a 3-sided micro-edge bezel for seamless multi-display tiling and 4-way adjustability so you can comfortably power through your day.
  • Break the boundaries
    Expand your productivity with uninterrupted views of one screen or many with a 3-sided micro-edge bezel that supports virtually seamless arrays. Get crisp visuals from any angle on the 1920 x 1080 Full HD resolution, 68.58 cm (27") diagonal IPS screen.
  • Work comfortably
    Find your most comfortable, productive position with adjustable tilt, height, swivel, and up to 150 mm height adjustment settings. Use pivot rotation to customize portrait or landscape views when using multiple displays.
  • Experience simple, convenient connectivity
    Work with your most frequently-used devices with VGA, HDMI, and DisplayPort . Connect your USB accessories right at the display with two USB 3.0 ports.
HP EliteDisplay E273 - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A+
Energy Consumption per Year
24 kWh
Power Consumption (On mode)
16 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms (On/Off)
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, anti-static
61.09 cm x 21.39 cm x 52.26 cm
7.02 kg
English / United Kingdom
Environmental Standards
TCO Certified Displays 7, TCO Certified Edge Displays, ENERGY STAR Qualified
Plug and Play, CSA, UL, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, MEPS, KC, CECP, CEL, EAC, ISC, low halogen, ICE, SmartWay
5-year warranty
Display Type
Energy Class
Class A+
24 kWh
16 W
Diagonal Size
27"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
250 cd/m²
Contrast Ratio
Response Time
5 ms (On/Off)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
HDCP, Mercury free, arsenic-free glass, Micro Edge
61.09 cm x 21.39 cm x 52.26 cm - with stand
7.02 kg
HDMI (HDCP) , DisplayPort (HDCP) , VGA , USB 3.0 upstream , 2 x USB 3.0 downstream
Mechanical
Tilt Angle
-5/+22
Swivel Angle
45
Rotation Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x DisplayPort cable , 1 x USB 3.0 to USB 3.0 type B cable
Security Slot Type
Kensington security slot
25 Watt
Power Consumption Stand by
0.3 Watt
Dimensions & Weight Details
With stand - width: 61.09 cm - depth: 21.39 cm - height: 52.26 cm - weight: 7.02 kg , Without stand - width: 61.09 cm - depth: 5.02 cm - height: 36.4 cm
TCO Certified
ENERGY STAR Certified
Limited warranty - 5 years - on-site - response time: next business day
5 °C
35 °C
20 - 80%
Diagonal Size: 27in
Response Time: 5ms
Speakers: None
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: HP
Price Range Ex VAT: 150 - 300
