Help protect your onscreen data in an instant with the HP EliteDisplay E243p Sure View Monitor. It's our first 23.8" diagonal display with an integrated privacy screen that's designed to shield sensitive content from prying eyes.
Safeguard your screen with one touch
Instantly create privacy in open workspaces and deter visual hacking with built-in HP Sure View Gen3 technology. No attachments, no replacements, no worries. -
Designed for functional flexibility
Experience practical sophistication in a forward-thinking, sleek design that also keeps you comfortable with 4-way adjustability-tilt, pivot, swivel, and up to 150 mm height adjustment. -
Explore every detail
Hide your screen from passersby and still get a crisp, clear, 1920 x 1080 FHD resolution view of your content, images, and video. Enjoy the productivity boost of a nearly-seamless, multi-display setup with the 3-sided micro-edge bezel.
- HP EliteDisplay E243p - LED monitor - Full HD (1080p) - 23.8"
- LED-backlit LCD monitor - 23.8" - HP SureView
- Energy Class
- Class E
- Energy Consumption per Year
- 23 kWh
- Power Consumption (On mode)
- 18.5 W
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.2745 mm
- Brightness
- 260 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 14 ms (grey-to-grey)
- Input Connectors
- HDMI, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, anti-static
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- Dimensions (WxDxH) - without stand
- 53.88 cm x 4.51 cm x 32.19 cm
- 3.48 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, CSA, UL, VCCI, BSMI, NOM, TUV S, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, ICES, MEPS, KC, CECP, CEL, EAC, ISC, SEPA, low halogen
- 5-year warranty
- Display Type
- Energy Class
- Class E
- 23 kWh
- Diagonal Size
- 23.8"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2745 mm
- Brightness
- 260 cd/m²
- Contrast Ratio
- Response Time
- Vertical Refresh Rate
- 60 Hz
- Horizontal Refresh Rate
- 80 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- Privacy Technology
- HP SureView
- HDCP, Full HD BrightView, Mercury free, arsenic-free glass
- Black
- 53.88 cm x 4.51 cm x 32.19 cm - without stand
- 3.48 kg
- HDMI (HDCP) , DisplayPort (HDCP) , VGA , USB 3.0 upstream (Type B) , 2 x USB 3.0 downstream (Type A)
Mechanical
- Tilt Angle
- -5/+22
- Swivel Angle
- 45
- Rotation Angle
- 90
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x DisplayPort cable , 1 x HDMI cable
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- 18.5 W
- Power Consumption SDR (On mode)
- 18.5 kWh/1000h
- Power Consumption (Typical)
- 40 Watt
- Power Consumption Stand by
- 0.5 Watt
- Included Software
- HP Display Assistant
- Dimensions & Weight Details
- With stand - width: 53.88 cm - depth: 20.5 cm - height: 46.3 cm - weight: 5.8 kg , Without stand - width: 53.88 cm - depth: 4.51 cm - height: 32.19 cm - weight: 3.48 kg
- Shipping Width
- 64.5 cm
- Shipping Depth
- 28.5 cm
- Shipping Height
- 42 cm
- Shipping Weight
- 9.8 kg
- ENERGY STAR Certified
- Limited warranty - parts and labour - 5 years - on-site
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
