Connect and collaborate in complete comfort on the HP EliteDisplay E243m 60.45 cm (23.8") Monitor, which is Skype for Business certified for optimal video and audio experiences between displays and has a 3-sided micro-edge bezel for seamless multi-display tiling and 4-way adjustable ergonomics.
Customizable collaboration
Personalize your setup by combining your display with an HP accessory designed for UCC, including wired and wireless headsets, a speaker phone, and keyboards with dedicated collaboration keys. -
Adaptable for a single-footprint setup
Mount your compatible HP Desktop Mini PC or select Thin Client or Chromebox directly on the column stand using the optional HP B300 PC Mounting Bracket. -
Experience simple, convenient connectivity
Connect to your most frequently-used displays and devices with a range of integrated ports right at the display. -
Be responsible
Reduce power consumption and help lower costs with a low halogen, ENERGY STAR certified, EPEAT 2019 registered display that meets TCO Certified Edge with 85% Post-Consumer Recycled plastics. -
Divide and conquer
Design the screen for how you work with HP Display Assistant software, which enables screen partitioning and helps deter theft by dimming a display that's disconnected without approval.
- HP EliteDisplay E243m - LED monitor - Full HD (1080p) - 23.8"
- LED-backlit LCD monitor - 23.8"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/298051
- Energy Class
- Class E
- Power Consumption (On mode)
- 17.5 W
- 2 microphones, USB 3.0 hub, 720p webcam
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 10000000:1 (dynamic)
- Response Time
- 5 ms (On/Off)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% NTSC
- Input Connectors
- HDMI, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black (rear cover), silver (speakers, bezel and stand)
- 53.88 cm x 21.4 cm x 51.37 cm
- 6.6 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, CSA, UL, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, MEPS, KC, CECP, EAC, ISC, CEL Grade 2, low halogen, ICE, SmartWay
- 5-year warranty
- Display Type
- Energy Class
- Class E
- Diagonal Size
- 23.8"
- Built-in Devices
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2745 mm
- Pixel Per Inch
- 93
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72% NTSC
- Response Time
- 5 ms (On/Off)
- Vertical Refresh Rate
- 50 - 60 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- WLED
- Colour Temperature
- 6500K
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
- HDCP, Frame Rate Control (FRC), Low Blue Light Mode, Flicker Free technology, Mercury free, arsenic-free glass, Bang & Olufsen audio, Micro Edge, 72% NTSC colour gamut
- 53.88 cm x 21.4 cm x 51.37 cm - with stand
- 6.6 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
- HDMI (HDCP) , DisplayPort (HDCP) , VGA , USB 3.0 upstream (Type B) , 2 x USB 3.0 downstream (Type A) , Audio line-in , Headphones
Mechanical
- Tilt Angle
- -5/+22
- Swivel Angle
- 90
- Rotation Angle
- 180
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), integrated cable management, detachable stand, direct mountable, VESA interface support
- Cables Included
- 1 x VGA cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x USB 3.0 to USB 3.0 type B cable - 1.8 m
- Backlight Life
- 30,000 hours
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- 17.5 W
- Power Consumption SDR (On mode)
- 17.5 kWh/1000h
- Power Consumption (Typical)
- 45 Watt
- Power Consumption Stand by
- 0.5 Watt
- On / Off Switch
- Included Software
- HP Display Assistant, Skype for Business
- Dimensions & Weight Details
- With stand - width: 53.88 cm - depth: 21.4 cm - height: 51.37 cm - weight: 6.6 kg , Without stand - width: 53.88 cm - depth: 4.63 cm - height: 34.72 cm - weight: 3.9 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 5 years - on-site - response time: next business day
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 4 Years On-Site | In Stock | £22.36 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site | In Stock | £32.96 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 1 Year On-Site | In Stock | £5.89 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Yrs On-Site for Monitor | In Stock | £10.59 |
