Style meets substance in a strikingly modern business display crafted for optimal viewing, productivity, and ergonomics. The HP EliteDisplay E243i 24-inch Monitor has a 3-sided micro-edge bezel for seamless multi-display tiling and 4-way adjustability so you can comfortably power through the day.
Adaptable for a single-footprint setup
Create an efficient, compact solution when you mount your compatible HP Desktop Mini PC, Thin Client or Chromebox directly on the column stand using the optional HP B300 PC Mounting Bracket. -
Be responsible
Reduce power consumption and help lower costs with a low halogen, ENERGY STAR certified, EPEAT 2019 registered display that meets TCO Certified Edge with 85% Post-Consumer Recycled plastics. -
Divide and conquer
Design the screen for how you work with HP Display Assistant software, which enables screen partitioning and helps deter theft by dimming a display that's disconnected without approval. -
Make it yours
Build a complete solution with optional HP accessories like an HP Single Arm to take the display off the desk, an HP USB Graphics Adapter for multi-display setups or an HP S100 Speaker Bar for space-saving audio.
- HP EliteDisplay E243i - LED monitor - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class F
- Energy Consumption per Year
- 38 kWh
- Power Consumption (On mode)
- 23 W
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:10
- Native Resolution
- WUXGA 1920 x 1200 at 60 Hz
- Pixel Pitch
- 0.27 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 10000000:1 (dynamic)
- Response Time
- 5 ms (On/Off)
- Input Connectors
- HDMI, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, anti-static
- Voltage
- AC 120/230 V
- Silver
- 53.2 cm x 21.39 cm x 36.23 cm
- 6.36 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, TUV GS, VCCI, BSMI, WHQL, CB, CCC, FCC, ISO 9241-307, WEEE, ICES, S Mark, cTUVus, ERP, CEL, ISC, RCM, MSIP, CoC, low halogen
- 5-year warranty
- Display Type
- Energy Class
- Class F
- 38 kWh
- Diagonal Size
- 24"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:10
- Native Resolution
- Pixel Pitch
- 0.27 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Response Time
- 5 ms (On/Off)
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- BrightView, HDCP, arsenic-free glass
- Silver
- 53.2 cm x 21.39 cm x 36.23 cm - with stand
- 6.36 kg
- HDMI (HDCP) , DisplayPort (HDCP) , VGA , USB 3.0 upstream (Type B) , 2 x USB 3.0 downstream (Type A)
Mechanical
- Tilt Angle
- -5/+23
- Swivel Angle
- 45
- Rotation Angle
- 90
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- AC 120/230 V
- 23 W
- Power Consumption SDR (On mode)
- 23 kWh/1000h
- Power Consumption (Typical)
- 35 Watt
- Power Consumption Stand by
- 0.5 Watt
- Dimensions & Weight Details
- With stand - width: 53.2 cm - depth: 21.39 cm - height: 36.23 cm - weight: 6.36 kg , Without stand - width: 53.2 cm - depth: 4.64 cm - height: 35.13 cm
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 5 years - on-site - response time: next business day
- 5 °C
- 35 °C
- 20 - 80%
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 4 Years On-Site | In Stock | £22.83 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site | In Stock | £33.64 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 1 Year On-Site | In Stock | £6.01 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Yrs On-Site for Monitor | In Stock | £10.81 |
