Style meets substance in a strikingly modern business display crafted for optimal viewing, productivity, and ergonomics. The HP EliteDisplay E243 23.8-inch monitor has a 3-sided micro-edge bezel for seamless multi-display tiling and 4-way adjustability so you can comfortably power through your day.
Break the boundaries
Expand your productivity with uninterrupted views of one screen or many with a 3-sided micro-edge bezel that supports virtually seamless arrays. Get crisp visuals from any angle on the 1920 x 1080 Full HD resolution, 60.45 cm (23.8") diagonal IPS screen. -
Work comfortably
Find your most comfortable, productive position with adjustable tilt, height, swivel, and up to 150 mm height adjustment settings. Use pivot rotation to customize portrait or landscape views when using multiple displays. -
Experience simple, convenient connectivity
Work with your most frequently-used devices with VGA, HDMI, and DisplayPort . Connect your USB accessories right at the display with two USB 3.0 ports.
 - HP EliteDisplay E243 - LED monitor - Full HD (1080p) - 23.8"
 - LED-backlit LCD monitor - 23.8"
- Energy Class
 - Class E
- Energy Consumption per Year
 - 26 kWh
- Power Consumption (On mode)
 - 16.9 W
 - USB 3.0 hub
- Panel Type
 - IPS
- Aspect Ratio
 - 16:9
- Native Resolution
 - Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
 - 0.2745 mm
- Brightness
 - 250 cd/m²
- Contrast Ratio
 - 1000:1 / 10000000:1 (dynamic)
- Response Time
 - 5 ms (On/Off)
- Input Connectors
 - HDMI, VGA, DisplayPort
 - Height, pivot (rotation), swivel, tilt
- Screen Coating
 - Anti-glare, anti-static
- Voltage
 - AC 120/230 V
 - 53.88 cm x 20.49 cm x 33.29 cm
 - 5.59 kg
- Localisation
 - English / United Kingdom
- Environmental Standards
 - ENERGY STAR Qualified
 - Plug and Play, TUV GS, VCCI, BSMI, WHQL, CB, CCC, FCC, ISO 9241-307, WEEE, ICES, S Mark, cTUVus, ERP, CEL, ISC, RCM, MSIP, CoC, low halogen
 - 5-year warranty
- Display Type
- Energy Class
 - Class E
 - 26 kWh
- Diagonal Size
 - 23.8"
- Built-in Devices
 - USB 3.0 hub
- Panel Type
 - IPS
- Aspect Ratio
 - 16:9
- Native Resolution
- Pixel Pitch
 - 0.2745 mm
- Brightness
 - 250 cd/m²
- Contrast Ratio
- Response Time
 - 5 ms (On/Off)
- Horizontal Viewing Angle
 - 178
- Vertical Viewing Angle
 - 178
- Screen Coating
- Backlight Technology
 - LED backlight
 - HDCP, Full HD BrightView
 - 53.88 cm x 20.49 cm x 33.29 cm - with stand
 - 5.59 kg
 - HDMI (HDCP) , DisplayPort (HDCP) , VGA , USB 3.0 upstream (Type B) , 2 x USB 3.0 downstream (Type A)
Mechanical
- Tilt Angle
 - -5/+20
- Swivel Angle
 - 90
- Rotation Angle
 - 90
- Height Adjustment
 - 150 mm
- VESA Mounting Interface
 - 100 x 100 mm
- Localisation
- Security Slot Type
 - Kensington security slot
- Input Voltage
 - AC 120/230 V
 - 16.9 W
- Power Consumption SDR (On mode)
 - 16.9 kWh/1000h
- Power Consumption (Typical)
 - 21 Watt
- Power Consumption Stand by
 - 0.5 Watt
Sustainability Information
- ENERGY STAR Certified
 - Limited warranty - 5 years - on-site - response time: next business day
 - 5 °C
 - 35 °C
 - 20 - 80%
                        HP Care Pack Next Business Day Hardware Support Extended Service Agreement 4 Years On-Site | In Stock | £22.36 |
                        HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site | In Stock | £32.96 |
                        HP Care Pack Next Business Day Hardware Support Extended Service Agreement 1 Year On-Site | In Stock | £5.93 |
                        HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Yrs On-Site for Monitor | In Stock | £10.59 |
