Be a master at multi-tasking with HP EliteDisplay E242 61 cm (24") Monitor, which delivers Full HD resolution, TCO Edge Certified comfort features, and an extra-large screen for all of your work.
Room to navigate
See more of your work onscreen at the same time with 1920 x 1200 resolution and a 16:10 aspect ratio on a 61 cm (24") diagonal screen. Collaborate easily with 178-degree viewing angle IPS technology that gives almost everyone in the room a great view. -
Suit yourself
Meet your comfort requirements and be more productive with adjustable tilt and swivel and an impressive 150 mm height adjustment range that combine to meet TCO Certified Edge requirements. Use pivot rotation to customize portrait or landscape views. -
Ports for your platforms and peripherals
Connect to a range of PCs and USB devices with HDMI, DisplayPort, VGA, and USB ports.
- HP EliteDisplay E242 - LED monitor - 24" - Smart Buy
- LED-backlit LCD monitor - 24"
- USB 2.0 hub
- Panel Type
- Plane to Line Switching (PLS)
- Aspect Ratio
- 16:10
- Native Resolution
- 1920 x 1200 at 60 Hz
- Pixel Pitch
- 0.27 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 7 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72%
- Input Connectors
- HDMI, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 56.22 cm x 18.9 cm x 51.9 cm
- 6.23 kg
- Localisation
- English / United Kingdom
- Pricing Type
- Promo
- Manufacturer Selling Program
- HP Smart Buy
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, CSA, UL, VCCI, BSMI, NOM, TUV S, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, MEPS, KC, CECP, CEL, EAC, ISC, SEPA
- Display Type
- Diagonal Size
- 24"
- Built-in Devices
- USB 2.0 hub
- Panel Type
- Aspect Ratio
- 16:10
- Native Resolution
- Pixel Pitch
- 0.27 mm
- Pixel Per Inch
- 93.9
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72%
- Response Time
- Vertical Refresh Rate
- 50 - 60 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Video Bandwidth
- 170 MHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- WLED
- Controls & Adjustments
- Brightness, contrast, input select, colour temperature
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
- HDCP, Mercury free, arsenic-free glass
- Black
- 56.22 cm x 18.9 cm x 51.9 cm - with stand
- 6.23 kg
- USB 2.0 upstream , 2 x USB 2.0 downstream , HDMI (HDCP) , DisplayPort (HDCP) , VGA
Mechanical
- Tilt Angle
- -5/+25
- Swivel Angle
- 90
- Rotation Angle
- 90
- Height Adjustment
- 150 mm
- Cables Included
- 1 x VGA cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x USB cable - 1.8 m
- Backlight Life
- 30,000 hours
- Localisation
- Pricing Type
- Promo
- HP Smart Buy
- Input Voltage
- Power Consumption (Typical)
- 30 Watt
- Power Consumption Stand by
- 0.5 Watt
- Included Software
- HP Display Assistant
- OS Required
- Microsoft Windows 7, Windows 8.1, Windows 10
- Dimensions & Weight Details
- Without stand - width: 56.22 cm - depth: 5 cm - height: 37.74 cm - weight: 4.2 kg , With stand - width: 56.22 cm - depth: 18.9 cm - height: 51.9 cm - weight: 6.23 kg
Sustainability Information
- ENERGY STAR Certified
- 5 °C
- 35 °C
- 20 - 80%
