Be a master at multi-tasking with HP EliteDisplay E242 61 cm (24") Monitor, which delivers Full HD resolution, TCO Edge Certified comfort features, and an extra-large screen for all of your work.
A compact, efficient PC-and-monitor workspace
Attach your HP Desktop Mini, HP Chromebox, or select HP Thin Client directly behind the display. Keep things tidy with an integrated power supply and cable management features. -
Reduce power consumption and help lower costs
Get an intelligent, energy-efficient design that is ENERGY STAR certified, EPEAT Gold registered, and meets TCO Certified Edge requirements. -
Your monitor's new best friend
Design the screen for how you work with HP Display Assistant software. -
Make it yours
Customize a complete solution with HP accessories designed and tested to work with your display.
- HP EliteDisplay E242 - LED monitor - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class A
- Energy Consumption per Year
- 33 kWh
- Power Consumption (On mode)
- 22 W
- USB 2.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:10
- Native Resolution
- 1920 x 1200 at 60 Hz
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 7 ms (grey-to-grey)
- Input Connectors
- HDMI, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V
- Black
- 56.22 cm x 18.9 cm x 51.9 cm
- 6.23 kg
- Localisation
- English / United Kingdom
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, CSA, UL, VCCI, BSMI, NOM, TUV S, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, KC, CECP, CEL, EAC, ISC, SEPA
- 3-year warranty
- Display Type
- Energy Class
- Class A
- 33 kWh
- Diagonal Size
- 24"
- Built-in Devices
- USB 2.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:10
- Native Resolution
- Brightness
- 250 cd/m²
- Contrast Ratio
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- HDCP, Mercury free, arsenic-free glass
- Black
- 56.22 cm x 18.9 cm x 51.9 cm - with stand
- 6.23 kg
- USB 2.0 upstream , 2 x USB 2.0 downstream , HDMI (HDCP) , DisplayPort (HDCP) , VGA
Mechanical
- Tilt Angle
- -5/+25
- Swivel Angle
- 90
- Rotation Angle
- 90
- Height Adjustment
- 150 mm
- Security lock slot (cable lock sold separately), integrated cable management
- Cables Included
- 1 x VGA cable , 1 x DisplayPort cable , 1 x USB cable
- Localisation
- Input Voltage
- AC 120/230 V
- 22 W
- Power Consumption (Typical)
- 38 Watt
- Power Consumption Stand by
- 0.5 Watt
- Included Software
- HP Display Assistant
- Dimensions & Weight Details
- Without stand - width: 56.22 cm - depth: 5 cm - height: 37.74 cm - weight: 4.2 kg , With stand - width: 56.22 cm - depth: 18.9 cm - height: 51.9 cm - weight: 6.23 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
- 5 °C
- 35 °C
- 20 - 80%
