Work smart and comfortably with the HP EliteDisplay E232 58,4 cm (23") Monitor, a large-screen Full HD IPS display with Elite-class presentation features and ergonomic adjustability for everything you do every day.
A compact, efficient PC-and-monitor workspace
Attach your HP Desktop Mini, HP Chromebox, or select HP Thin Client directly behind the display. Keep things tidy with an integrated power supply and cable management features. -
Reduce power consumption and help lower costs
Get an intelligent, energy-efficient design that is ENERGY STAR certified, EPEAT Gold registered, and meets TCO Certified Edge requirements with 85% Post-Consumer Recycled plastics. -
Your monitor's new best friend
Design the screen for how you work with HP Display Assistant software. -
Make it yours
Customize a complete solution with HP accessories. Use the HP Speaker Bar for audio, an HP Single Arm to take the display off the desk, or an HP USB Graphics Adapter for multi-monitor setups. Go stand-less with the head-only model. -
Backed by world-class support specialists
Get three years of service and support, and extend your protection with optional HP Care Packs.
- HP EliteDisplay E232 - LED monitor - Full HD (1080p) - 23"
- LED-backlit LCD monitor - 23"
- Energy Class
- Class A
- Energy Consumption per Year
- 28 kWh
- Power Consumption (On mode)
- 19 W
- USB 2.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.265 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 7 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72%
- Input Connectors
- HDMI, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 54.93 cm x 18.9 cm x 54.99 cm
- 5.7 kg
- Localisation
- English / United Kingdom
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, CSA, UL, VCCI, BSMI, NOM, TUV S, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, KC, CECP, CEL, EAC, ISC, SEPA
- 3-year warranty
- Display Type
- Energy Class
- Class A
- 28 kWh
- Diagonal Size
- 23"
- Built-in Devices
- USB 2.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.265 mm
- Pixel Per Inch
- 96
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72%
- Response Time
- Vertical Refresh Rate
- 50 - 60 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Video Bandwidth
- 170 MHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- WLED
- Controls & Adjustments
- Brightness, contrast, input select
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
- HDCP, On-screen Digital Controls
- Black
- 54.93 cm x 18.9 cm x 54.99 cm - with stand
- 5.7 kg
- USB 2.0 upstream , 2 x USB 2.0 downstream , VGA , DisplayPort (HDCP) , HDMI (HDCP)
Mechanical
- Tilt Angle
- -5/+30
- Swivel Angle
- 45
- Rotation Angle
- 90
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), detachable stand
- Cables Included
- 1 x VGA cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x USB cable - 1.8 m
- Backlight Life
- 30,000 hours
- Localisation
- Input Voltage
- 19 W
- Power Consumption (Typical)
- 28 Watt
- Power Consumption Stand by
- 0.5 Watt
- Included Software
- Display drivers, HP Display Assistant
- Dimensions & Weight Details
- Without stand - width: 54.93 cm - depth: 4.96 cm - height: 33.69 cm - weight: 3.63 kg , With stand - width: 54.93 cm - depth: 18.9 cm - height: 54.99 cm - weight: 5.7 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
