HP EliteDisplay E232 23" 1920x1080 7ms VGA HDMI DisplayPort IPS LED Monitor
Quicklinx: BVP6WS00 Mfr#: M1N98AA#ABU
Work smart and comfortably with the HP EliteDisplay E232 58,4 cm (23") Monitor, a large-screen Full HD IPS display with Elite-class presentation features and ergonomic adjustability for everything you do every day.
  • A compact, efficient PC-and-monitor workspace
    Attach your HP Desktop Mini, HP Chromebox, or select HP Thin Client directly behind the display. Keep things tidy with an integrated power supply and cable management features.
  • Reduce power consumption and help lower costs
    Get an intelligent, energy-efficient design that is ENERGY STAR certified, EPEAT Gold registered, and meets TCO Certified Edge requirements with 85% Post-Consumer Recycled plastics.
  • Your monitor's new best friend
    Design the screen for how you work with HP Display Assistant software.
  • Make it yours
    Customize a complete solution with HP accessories. Use the HP Speaker Bar for audio, an HP Single Arm to take the display off the desk, or an HP USB Graphics Adapter for multi-monitor setups. Go stand-less with the head-only model.
  • Backed by world-class support specialists
    Get three years of service and support, and extend your protection with optional HP Care Packs.
HP EliteDisplay E232 - LED monitor - Full HD (1080p) - 23"
LED-backlit LCD monitor - 23"
Energy Class
Class A
Energy Consumption per Year
28 kWh
Power Consumption (On mode)
19 W
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
7 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
72%
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
54.93 cm x 18.9 cm x 54.99 cm
5.7 kg
English / United Kingdom
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Plug and Play, CSA, UL, VCCI, BSMI, NOM, TUV S, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, KC, CECP, CEL, EAC, ISC, SEPA
3-year warranty
Display Type
Energy Class
Class A
28 kWh
Diagonal Size
23"
Built-in Devices
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Pixel Per Inch
96
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72%
Response Time
7 ms (grey-to-grey)
Vertical Refresh Rate
50 - 60 Hz
Horizontal Refresh Rate
30 - 80 kHz
Video Bandwidth
170 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
Controls & Adjustments
Brightness, contrast, input select
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
HDCP, On-screen Digital Controls
54.93 cm x 18.9 cm x 54.99 cm - with stand
5.7 kg
USB 2.0 upstream , 2 x USB 2.0 downstream , VGA , DisplayPort (HDCP) , HDMI (HDCP)
Mechanical
Tilt Angle
-5/+30
Swivel Angle
45
Rotation Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand
1 x VGA cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x USB cable - 1.8 m
Backlight Life
30,000 hours
Input Voltage
19 W
Power Consumption (Typical)
28 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Display drivers, HP Display Assistant
Dimensions & Weight Details
Without stand - width: 54.93 cm - depth: 4.96 cm - height: 33.69 cm - weight: 3.63 kg , With stand - width: 54.93 cm - depth: 18.9 cm - height: 54.99 cm - weight: 5.7 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
5 °C
35 °C
20 - 80% (non-condensing)
