Work smart and comfortably with the HP EliteDisplay E232 58,4 cm (23") Monitor, a large-screen Full HD IPS display with Elite-class presentation features and ergonomic adjustability for everything you do every day.
Put every detail on display.
Enjoy sharp Full HD resolution for all your projects and collaborate easily with colleagues around the room with 178-degree viewing angles from IPS technology. The large 58,4 cm (23") diagonal screen gives you plenty of room for your open applications.
Convenient connections.
Connect to your choice of PC or device with HDMI, DisplayPort, VGA, and USB inputs. Keep your frequently-used devices right where you need them with USB connections at the display.
Find your perfect fit.
Create the view that’s right for you and boost your productivity with adjustable tilt and swivel and an impressive 150 mm height adjustment range. Use pivot rotation to customize portrait or landscape views.
Enjoy sharp Full HD resolution for all your projects and collaborate easily with colleagues around the room with 178-degree viewing angles from IPS technology. The large 58,4 cm (23") diagonal screen gives you plenty of room for your open applications. -
Create the view that's right for you and boost your productivity with adjustable tilt and swivel and an impressive 150 mm height adjustment range. Use pivot rotation to customize portrait or landscape views. -
- HP EliteDisplay E232 - LED monitor - Full HD (1080p) - 23" - Smart Buy
- LED-backlit LCD monitor - 23"
- Energy Class
- Class A
- Energy Consumption per Year
- 28 kWh
- Power Consumption (On mode)
- 19 W
- USB 2.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.265 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 7 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72%
- Input Connectors
- HDMI, VGA, DisplayPort
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 54.93 cm x 18.9 cm x 54.99 cm
- 5.7 kg
- Localisation
- English / United Kingdom
- Manufacturer Selling Program
- HP Smart Buy
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- 3-year warranty
- Display Type
- Energy Class
- Class A
- 28 kWh
- Diagonal Size
- 23"
- Built-in Devices
- USB 2.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.265 mm
- Pixel Per Inch
- 96
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72%
- Response Time
- Vertical Refresh Rate
- 50 - 60 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Video Bandwidth
- 170 MHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- WLED
- Controls & Adjustments
- Brightness, contrast, input select
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
- HDCP, On-screen Digital Controls
- Black
- 54.93 cm x 18.9 cm x 54.99 cm - with stand
- 5.7 kg
- USB 2.0 upstream , 2 x USB 2.0 downstream , VGA , DisplayPort (HDCP) , HDMI (HDCP)
Mechanical
- Tilt Angle
- -5/+30
- Swivel Angle
- 45
- Rotation Angle
- 90
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), detachable stand
- Cables Included
- 1 x VGA cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x USB cable - 1.8 m
- Backlight Life
- 30,000 hours
- Localisation
- HP Smart Buy
- Input Voltage
- 19 W
- Power Consumption (Typical)
- 28 Watt
- Power Consumption Stand by
- 0.5 Watt
- Included Software
- HP Display Assistant
- Dimensions & Weight Details
- Without stand - width: 54.93 cm - depth: 4.96 cm - height: 33.69 cm - weight: 3.63 kg , With stand - width: 54.93 cm - depth: 18.9 cm - height: 54.99 cm - weight: 5.7 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
- 5 °C
- 35 °C
- 20 - 80%
