HP EliteDisplay E231 23" 1920x1080 5ms VGA DVI DisplayPort LED Monitor
Quicklinx: BKTJWS00 Mfr#: C9V75AA#ABU
Give your business-critical users the display they crave. The HP EliteDisplay E231 58,4 cm (23') LED Backlit Monitor delivers outstanding ergonomic adjustability and convenient connectivity in a premier, energy efficient design.
  • Enhance your view, advance your connectivity
    Bring your content to life with Full-HD resolution. Get vibrant text and graphics from the LED backlit panel, which also makes the monitor thin, light, and easy to position on a desk.Deliver clear views with wide viewing angles, and keep your content crisp and readable with high contrast ratios and fast response times.Easily connect devices with convenient VGA, DVI, and DisplayPort inputs and an integrated USB hub.Work on a document in one partition, refer to a spreadsheet in another, and check e-mails in another-at the same time with HP Display Assistant. Customize your workspace with resizable screen partitions through an easy-to-use, centralized interface.Use HP Display Assistant's new expanded toolbar to view open applications on all of your connected displays. Deter theft with a user-designated PIN that deactivates the monitor if it's disconnected from a PC without approval.
  • Get comfortable with HP's ultimate adjustable design
    Find your most comfortable working position so you can power through your day. Customizable tilt, height adjustment, swivel, and pivot settings-the most adjustability available on an HP business display-help you find your sweet spot.
  • Control your environmental impact
    Reduce power consumption and help lower your costs with an intelligent, energy efficient design that carries ENERGY STAR , EPEAT Gold , and TCO certifications.Help decrease your eco-footprint with Mercury-free LED display backlighting, a low-halogen design and arsenic-free display glass.
  • Global reassurance
    Rest assured that your IT investment is supported by a three-year standard limited warranty. Select optional HP Care Pack Services to extend your protection beyond the standard warranties.Get award-winning service and support by phone or online.
HP EliteDisplay E231 - LED monitor - Full HD (1080p) - 23"
LED-backlit LCD monitor - 23"
USB 2.0 hub
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
54.4 cm x 5.1 cm x 32.9 cm
6.1 kg
English / United Kingdom
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Plug and Play, MPR II
Display Type
Diagonal Size
23"
Built-in Devices
USB 2.0 hub
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
Response Time
5 ms
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Anti-glare
Backlight Technology
LED backlight
HDCP, On-screen Digital Controls, PIN code protection
54.4 cm x 5.1 cm x 32.9 cm - without stand
6.1 kg
USB 2.0 upstream (Type B) , 2 x USB 2.0 downstream (Type A) , DVI-D (HDCP) , DisplayPort (HDCP) , VGA (HD-15)
Mechanical
Tilt Angle
-5/+30
Swivel Angle
360
1 x VGA cable , 1 x DisplayPort cable , 1 x USB cable
Input Voltage
Power Consumption (Typical)
36 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Dimensions & Weight Details
Without stand - width: 54.4 cm - depth: 5.1 cm - height: 32.9 cm - weight: 6.1 kg , With stand - width: 54.4 cm - depth: 24.24 cm - height: 46.99 cm
Sustainability Information
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
5 °C
35 °C
20 - 80%
