Clear your clutter with the easy, efficient connectivity of the HP EliteDisplay E223d 21.5-inch Docking Monitor. Set up your devices and network at the display one time, then connect your notebook through just one USB-C cable and you're ready to work.
Adjust your view
Filter blue light emission and shift colors to a warmer spectrum for more comfortable viewing with HP Low Blue Light mode. -
Complete the picture
Customize a total solution with options like the HP S101 Speaker Bar, which attaches easily to the lower bezel to add stereo audio at the display. -
Divide and conquer
Manage your display and make it work for you. HP Display Assistant allows you to quickly resize screen partitions so you can work in separate regions of the screen and helps deter theft by dimming a display that's disconnected without approval. -
We have your back
Rest assured that your IT investment is supported with our three-year standard limited warranty. To extend your protection, select an optional HP Care service.
- HP EliteDisplay E223d Docking Monitor - LED monitor - Full HD (1080p) - 21.5" - Smart Buy
- LED-backlit LCD monitor - 21.5"
- USB 3.1 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.274 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Input Connectors
- HDMI, USB-C
- Pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- 48.83 cm x 20.5 cm x 44.86 cm
- 5.08 kg
- Localisation
- English / United Kingdom
- Manufacturer Selling Program
- HP Smart Buy
- Plug and Play, TUV GS, VCCI, BSMI, NOM, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, ICES, cTUVus, MEPS, KC, CEL, EAC, ISC, BIS, low halogen
- 3-year warranty
- Display Type
- Diagonal Size
- 21.5"
- Built-in Devices
- USB 3.1 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.274 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Response Time
- Vertical Refresh Rate
- 60 Hz
- Horizontal Refresh Rate
- 80 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- HDCP, On-screen Digital Controls, Mercury free, arsenic free
- 48.83 cm x 20.5 cm x 44.86 cm - with stand
- 5.08 kg
- HDMI (HDCP) , USB-C , Network , USB 3.1 upstream (Type B) , 4 x USB 3.1 downstream (Type A) , Audio line-in/out
Mechanical
- Tilt Angle
- -5/+23
- Swivel Angle
- 90
- Rotation Angle
- 90
- VESA Mounting Interface
- VESA
- Security lock slot (cable lock sold separately), detachable stand
- Cables Included
- 1 x USB cable , 1 x USB-C cable
- Localisation
- HP Smart Buy
- Security Slot Type
- Kensington security slot
- Input Voltage
- Power Consumption (Typical)
- 15 Watt
- Power Consumption Stand by
- 0.3 Watt
- Included Software
- HP Display Assistant
- Dimensions & Weight Details
- Without stand - width: 48.83 cm - depth: 4.483 cm - height: 29.33 cm
- Shipping Width
- 58.9 cm
- Shipping Depth
- 27.3 cm
- Shipping Height
- 36.5 cm
- Shipping Weight
- 8.06 kg
- Limited warranty - parts and labour - 3 years
- 5 °C
- 35 °C
- 20 - 80%
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 4 Years On-Site | In Stock | £22.36 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site | In Stock | £32.96 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 1 Year On-Site | In Stock | £5.93 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Yrs On-Site for Monitor | In Stock | £10.59 |
