HP EliteDisplay E202 20" Monitor
Quicklinx: C5H4WS00 Mfr#: M1F41AT#ABU
Get comfortable and be productive with the affordable, easy-to-deploy HP EliteDisplay E202 50,8 cm (20") Monitor, an HD+ IPS display that is Certified for Windows 10 and includes excellent ergonomic adjustability and crisp, clear color presentation.
  • A compact, efficient PC-and-monitor workspace
    Attach your HP Desktop Mini, HP Chromebox, or select HP Thin Client directly behind the display. Keep things tidy with an integrated power supply and cable management features.
  • Certified for Windows 10
    Connect the display to your PC or notebook and experience all Windows 10 has to offer.
  • Reduce power consumption and help lower costs
    Get an intelligent, energy-efficient design that is ENERGY STAR certified, EPEAT 2019 registered, and meets TCO Certified Edge requirements with 85% Post-Consumer Recycled plastics.
  • Your monitor's new best friend
    Design the screen for how you work with HP Display Assistant software.
  • Make it yours
    Customize a complete solution with HP accessories. Add audio with the HP Speaker Bar, use an HP Single Arm to take the display off the desk, or choose an HP USB Graphics Adapter for multi-monitor5 setups.
HP EliteDisplay E202 - LED monitor - 20" - Smart Buy
LED-backlit LCD monitor - 20"
Energy Class
Class E
Energy Consumption per Year
26 kWh
Power Consumption (On mode)
18 W
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
1600 x 900 at 60 Hz
Pixel Pitch
0.27675 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
7 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
72%
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
47.9 cm x 18.9 cm x 49.33 cm
4.8 kg
English / United Kingdom
Manufacturer Selling Program
HP Smart Buy
Environmental Standards
ENERGY STAR Qualified
CSA, UL, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, ISO 9241-307, KCC, WEEE, MEPS, KC, CECP, CEL, EAC, ISC, SEPA
5-year warranty
Display Type
Energy Class
Class E
26 kWh
Diagonal Size
20"
Built-in Devices
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
1600 x 900 at 60 Hz
Pixel Pitch
0.27675 mm
Pixel Per Inch
0.27675
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72%
Response Time
7 ms (grey-to-grey)
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
30 - 70 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
Controls & Adjustments
Brightness, contrast
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
HDCP
47.9 cm x 18.9 cm x 49.33 cm - with stand
4.8 kg
USB 2.0 upstream (Type B) , 2 x USB 2.0 downstream (Type A) , HDMI (HDCP) , DisplayPort (HDCP) , VGA (HD-15)
Mechanical
Tilt Angle
-5/+25
Swivel Angle
90
Rotation Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
1 x VGA cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x USB cable - 1.8 m
Backlight Life
40,000 hours
HP Smart Buy
Input Voltage
18 W
14 kWh/1000h
Power Consumption (Typical)
22 Watt
Power Consumption Stand by
0.5 Watt
Sustainability Information
ENERGY STAR Certified
Limited warranty - 5 years - on-site - response time: next business day
5 °C
35 °C
20 - 80% (non-condensing)
C5H4 HP Care Pack Next Business Day Hardware Support Extended Service Agreement 4 Years On-Site In Stock £22.36
C5H4 HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site In Stock £32.96
C5H4 HP Care Pack Next Business Day Hardware Support Extended Service Agreement 1 Year On-Site In Stock £6.01
C5H4 HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Yrs On-Site for Monitor In Stock £10.59
