HP EliteDesk 800 G6 Mini Desktop Intel Core i5-10500T 8GB 256GB SSD Windows 10 Professional 64-bit
Quicklinx: GM2XWS00 Mfr#: 1D2L7EA#ABU
  • Core i5
  • IEEE 802.11n
Get to work fast with the compact, high-performance HP EliteDesk 800 Desktop Mini. It's designed for the open office with improved acoustics to help you focus, HP Extended Range Wireless LAN that quickly cuts through network clutter, and scalable features for your specific deployment.
  • Windows 11
    Work anywhere without compromising on performance or security with Windows 11 powered by HP's collaboration and connectivity technology.
  • Fast performance, connectivity, and responsiveness
    Get the exceptional combination of responsive performance, connectivity and speed with a 10th Gen Intel Core processor that lets you launch, create, and connect fast and reliably.
  • Fast and efficient wireless LAN
    The portability of your PC and the reliability of a fast connection determines where you can work. Get a fast and reliable connection in dense wireless environments with gigabit-speed Wi-Fi 6.
  • HP Sure Sense
    Malware is evolving rapidly and traditional antivirus can't always recognize new attacks. Protect your PC against never-before-seen attacks with HP Sure Sense, which uses deep learning AI to provide exceptional protection against advanced malware.
  • Protect critical security processes
    Keep your critical applications and processes running even if malware tries to shut them down with the self-healing protection of HP Sure Run.
  • Browse confidently
    Help protect your PC from websites and read only Microsoft Office and PDF attachments with embedded malware, ransomware, or viruses with hardware-enforced security from HP Sure Click.
HP EliteDesk 800 G6 - mini desktop Core i5 10500T 2.3 GHz - vPro - 8 GB - SSD 256 GB - UK
Personal computer - mini desktop
Platform Technology
Intel vPro Platform
Intel Core i5 (10th Gen) 10500T / 2.3 GHz (6-core)
Cache Memory
12 MB
Cache Per Processor
12 MB
RAM
8 GB (installed) / 64 GB (max) - DDR4 SDRAM - non-ECC
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
SSD 256 GB - PCI Express 3.0 - M.2 2280 - NVM Express (NVMe), triple-level cell (TLC)
Optical Storage
No optical drive
Graphics Controller
Intel UHD Graphics 630 Dynamic Video Memory Technology
Audio Output
Stereo
1GbE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 5.1, Wi-Fi 6
Keyboard
(50/60 Hz)
OS Provided
Windows 10 Pro 64-bit Edition
Software Included
HP Support Assistant, Windows Defender, HP Secure Erase, HP BIOS Configuration Utility (free download), HP Client Catalogue (free download), HP Setup Integrated OOBE, HP Image Assistant (free download), HP JumpStart, HP Noise Cancellation, HP System Software Manager (free download), HP Privacy Settings, HP Cloud Recovery, HP Client Management Script Library (free download), HP BIOSphere Gen6, HP Wake on WLAN, HP Desktop Support Utility, HP Manageability Integration Kit for Microsoft System Centre Configuration Manager Gen4 (free download), HP Client Security Suite Gen6
17.7 cm x 17.5 cm x 3.4 cm
1.42 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years - on-site
Platform Technology
Intel vPro Platform
Personal computer
Product Form Factor
Mini desktop
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Clock Speed
2.3 GHz
Number of Cores
6-core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Chipset Type
Intel Q470
Cache Memory
Installed Size
12 MB
Cache Per Processor
12 MB
RAM
Installed Size
Effective Memory Speed
2666 MHz
Rated Memory Speed
2666 MHz
SO-DIMM 260-pin
Slots
2 (Total) / 1 (empty)
Unbuffered
Configuration Features
1 x 8 GB
Hard Drive
SSD - M.2 2280
1 x 256 GB
Interface Type
PCI Express 3.0
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
DisplayPort
HDCP Compatible
Audio Output
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP 320K
USB
Localization & Layout
Mouse
Optical
USB
Ethernet Controller
Intel I219-LM
Wireless LAN Supported
Wireless NIC
Intel Wi-Fi 6 AX 201
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 5.1, IEEE 802.11ax (Wi-Fi 6)
Remote Management Protocol
SNMP 2
Wake on LAN (WoL), ACPI support, PXE 2.1 support, dual stream (2x2)
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.3x, IEEE 802.11d, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11h, IEEE 802.11e, IEEE 802.11n, IEEE 802.11k, IEEE 802.3az, IEEE 802.11ac, IEEE 802.11r, IEEE 802.11v, IEEE 802.11ax, Bluetooth 5.1
Bays
1 (total) / 1 (free) x internal 2.5"
Slots
1 (total) / 0 (free) x M.2 Card - 2230 (x1 mode) , 2 (total) / 1 (free) x M.2 Card - 2230/2280 (x4 mode)
3 x USB 3.2 Gen 1 (1 front, 2 rear) , 3 x USB 3.2 Gen 2 (1 front, 2 rear) , 1 x USB-C 3.2 Gen 2 (1 in front) , 2 x DisplayPort 1.4 , 1 x headphones/microphone (1 in front) (CTIA and OMTP headset support) , 1 x LAN (Gigabit Ethernet) , 1 x DisplayPort/USB-C 3.2 Gen 2 (charging with Alternate mode) , 2 x USB 2.0
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
Security Slot Type
Kensington security slot
FCC Class B certified, ICES-003, CCC, RoHS, UL 60950-1, CSA C22.2 No. 60950-1-07, WEEE, KCC Class B, Common Criteria EAL4+, CECP, VCCI Class B, SEPA, low halogen, UL 62368-1, CAN/CSA-C22.2 No. 62368-1-14
Power adapter
AC 100-240 V (50/60 Hz)
Power Provided
65 watt
Efficiency
89% (230VAC), 88% (115VAC)
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition English
Software
Sustainability Information
ENERGY STAR Certified
17.7 cm
17.5 cm
3.4 cm
1.42 kg
Shipping Width
49.8 cm
Shipping Depth
13.2 cm
Shipping Height
23.5 cm
Shipping Weight
2.95 kg
10 °C
35 °C
10 - 90% (non-condensing)
Warranties (6)
GM2X HP 3 Year NBD On-Site Optional Customer Self Repair Desktop/Workstation Only Hardware Service In Stock £32.96
GM2X HP Care Pack Next Business Day HW Support Post Warranty Extended Service Agreement 1 Year On-Site In Stock £27.34
GM2X HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site In Stock £34.13
GM2X HP Care Pack NBD Hardware Support with Disk Retention Extended Service Agreement 3 Years On-Site In Stock £69.44
GM2X HP Care Pack NBD HW Support w/ Defective Media Retention Extended Service Agreement 4 Years On-Site In Stock £57.67
GM2X HP Care Pack NBD Hardware Support with Disk Retention Extended Service Agreement 5 Years On-Site In Stock £80.03
Other bundles (3)
GM2X HPE DisplayPort DVI-D Adapter In Stock £19.94
GM2X HPE USB to Serial Port Adapter In Stock £13.95
GM2X HP USB-C To VGA Adapter In Stock £23.07
