HP EliteDesk 800 G6 Intel Core i5-10500 8GB 256GB SSD Windows 10 Professional 64-bit
Quicklinx: GLDRWS00 Mfr#: 4H699EA#ABU
  • Core i5
  • IEEE 802.11n
The redesigned HP EliteDesk 800 Small Form Factor delivers high performance and broad expandability in a compact business-class SFF PC. Featuring powerful components, and strong security, this small PC handles big workloads.
  • Windows 10 Pro
    Work anywhere without compromising on performance or security with Windows 10 Pro. FREE upgrade to Windows 11 when available.
  • Fast performance, connectivity, and responsiveness
    Get the exceptional combination of responsive performance, connectivity and speed with a 10th Gen Intel Core processor that lets you launch, create, and connect fast and reliably.
  • Security is your top priority
    The HP Wolf Pro Security Edition provides preconfigured enterprise-level PC protection for small and medium sized businesses.
  • HP Sure Sense
    Malware is evolving rapidly and traditional antivirus can't always recognize new attacks. Protect your PC against never-before-seen attacks with HP Sure Sense, which uses deep learning AI to provide exceptional protection against advanced malware.
  • Fast and efficient wireless LAN
    The portability of your PC and the reliability of a fast connection determines where you can work. Get a fast and reliable connection in dense wireless environments with gigabit-speed Wi-Fi 6.
  • Protect critical security processes
    Keep your critical applications and processes running even if malware tries to shut them down with the self-healing protection of HP Sure Run.
HP EliteDesk 800 G6 - SFF Core i5 10500 3.1 GHz - vPro - 8 GB - SSD 256 GB - UK - with HP Wolf Pro Security Edition (3 years)
Personal computer - SFF
Platform Technology
Intel vPro Platform
Intel Core i5 (10th Gen) 10500 / 3.1 GHz (up to 4.5 GHz, (6-core)
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2, Intel Smart Cache
Cache Memory
12 MB
Cache Per Processor
12 MB
RAM
8 GB (installed) / 128 GB (max) - DDR4 SDRAM - non-ECC - PC4-21333
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
SSD 256 GB - PCI Express - M.2 2280 - NVM Express (NVMe), triple-level cell (TLC)
Optical Storage
No optical drive
Graphics Controller
Intel UHD Graphics 630 Dynamic Video Memory Technology
Audio Output
Stereo
1GbE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 5.0, Wi-Fi 6
Keyboard
(50/60 Hz)
OS Provided
Windows 10 Pro 64-bit Edition
Software Included
HP Client Catalog, HP Driver Packs, HP BIOS Config Utility, HP Cloud Recovery, HP Image Assistant Gen5, HP Pro Security Edition, HP Smart Support, HP Management Integration Kit for Microsoft System Center Configuration Manager Gen 4
33.8 cm x 30.8 cm x 10 cm
6.13 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years - on-site
Bundled with
Platform Technology
Intel vPro Platform
Personal computer
Product Form Factor
SFF
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Bundled with
Processor / Chipset
CPU
Clock Speed
3.1 GHz
Max Turbo Speed
4.5 GHz
Number of Cores
6-core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Chipset Type
Intel Q470
Cache Memory
Installed Size
12 MB
Cache Per Processor
12 MB
RAM
Installed Size
Effective Memory Speed
2666 MHz
Rated Memory Speed
2666 MHz
Memory Specification Compliance
PC4-21333
DIMM 288-pin
Slots
4 (Total) / 3 (empty)
Configuration Features
1 x 8 GB
Hard Drive
SSD - M.2 2280
1 x 256 GB
Interface Type
PCI Express
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Channel Qty
3
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
DisplayPort
HDCP Compatible
Audio Output
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP 320K
Localization & Layout
Mouse
Optical
USB
Ethernet Controller
Intel I219-LM
Wireless LAN Supported
Wireless NIC
Intel Wi-Fi 6 AX 201
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 5.0, IEEE 802.11ax (Wi-Fi 6)
Remote Management Protocol
SNMP 2
Wake on LAN (WoL), ACPI support, auto-uplink (auto MDI/MDI-X), PXE 2.1 support, MIMO support, dual stream (2x2)
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.3x, IEEE 802.11d, IEEE 802.11g, IEEE 802.11i, IEEE 802.11h, IEEE 802.11e, IEEE 802.11n, IEEE 802.11k, IEEE 802.3az, IEEE 802.11ac, IEEE 802.11r, IEEE 802.11v, IEEE 802.11ax, Bluetooth 5.1
Bays
1 (total) / 1 (free) x external 5.25" Slim Line , 1 (total) / 1 (free) x external , 1 (total) / 1 (free) x internal 2.5" , 2 (total) / 2 (free) x internal 3.5"
Slots
1 (total) / 0 (free) x M.2 Card - 2230 (x1 mode) , 2 (total) / 1 (free) x M.2 Card - 2242/2280 (x4 mode) , 2 (total) / 2 (free) x PCIe 3.0 x1 , 1 (total) / 1 (free) x PCIe 3.0 x16 (x4 mode) , 1 (total) / 1 (free) x PCIe 3.0 x16 (75W max power)
2 x USB 2.0 (wake functionality) , 4 x USB 3.2 Gen 1 (2 front, 2 rear) (one of them is fast-charging) , 4 x USB 3.2 Gen 2 (2 front, 2 rear) , 1 x USB-C 3.2 Gen 2 (1 in front) (charging) , 2 x DisplayPort 1.4 , 1 x headphones/microphone (1 in front) (CTIA and OMTP headset support) , 1 x audio line-out , 1 x LAN (Gigabit Ethernet)
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
FCC Class B certified, ICES-003, CCC, UL 60950-1, CSA C22.2 No. 60950-1-07, KCC Class B, CECP, VCCI Class B, WEEE 2002/96/EC, SEPA, UL 62368-1, RoHS 2011/65/EC, CAN/CSA-C22.2 No. 62368-1-14
Power supply
AC 90-264 V (50/60 Hz)
Power Provided
260 watt
80 PLUS Certification
80 PLUS Platinum
Efficiency
90% at 20% Load (115 VAC), 92% at 50% Load (115 VAC), 89% at 100% Load (115 VAC), 91% at 20% Load (230 VAC), 93% at 50% Load (230 VAC), 90% at 100% Load (230 VAC)
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition English
Software
Sustainability Information
ENERGY STAR Certified
33.8 cm
30.8 cm
10 cm
6.13 kg
Shipping Width
39.9 cm
Shipping Depth
49.9 cm
Shipping Height
23 cm
Shipping Weight
9 kg
10 °C
35 °C
10 - 90% (non-condensing)
Warranties (6)
GLDR HP 3 Year NBD On-Site Optional Customer Self Repair Desktop/Workstation Only Hardware Service In Stock £33.64
GLDR HP Care Pack Next Business Day HW Support Post Warranty Extended Service Agreement 1 Year On-Site In Stock £26.43
GLDR HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site In Stock £34.84
GLDR HP Care Pack NBD Hardware Support with Disk Retention Extended Service Agreement 3 Years On-Site In Stock £70.87
GLDR HP Care Pack NBD HW Support w/ Defective Media Retention Extended Service Agreement 4 Years On-Site In Stock £58.87
GLDR HP Care Pack NBD Hardware Support with Disk Retention Extended Service Agreement 5 Years On-Site In Stock £81.69
Other bundles (4)
GLDR HPE DisplayPort DVI-D Adapter In Stock £19.77
GLDR HPE DisplayPort to VGA Adapter In Stock £13.14
GLDR HPE USB to Serial Port Adapter In Stock £13.95
GLDR HP USB-C To VGA Adapter In Stock £23.07
