HP EliteDesk 800 G3 SFF Intel Core i7 7700 8GB 256GB SSD
Quicklinx: CT9VWS00 Mfr#: Z4D05ET#ABU
  • Core i7
Powered for the enterprise, the HP EliteDesk 800 is a secure and manageable PC featuring advanced performance, and configurability in a space saving, stylishly redesigned chassis for the modern workplace.
Performance first
High-performance users will enjoy the powerful combination of 7th Gen Intel® Core™ processors , optional Intel® Optane™ memory and SSDs , and HP Velocity that improves data transfer rates over challenged networks to drive productivity in the workplace.
Expansion that extends your investment
The full value of your investment comes with configuration that extends the life of your PC. The HP EliteDesk 800 SFF has four bays and four slots, plus two additional M.2 connectors, and plenty of configurable ports.
Strong security, powerful manageability
Get powerful protection and simplified management from HP’s most secure and manageable PCs. HP Sure Start Gen3 protects against BIOS attacks while the HP Manageability Integration Kit allows you to easily manage devices through Microsoft System Center Configuration Manager
Configurable I/O Port for displays
Configure a rear I/O port for customizable display connections with your choice of VGA, DisplayPort™, HDMI or USB Type-C™ alternate mode DisplayPort™.
  • Let nothing stand in your way
    Power through your day with Windows 10 Pro and the powerful HP EliteDesk 800 SFF with built-in security, collaboration, and connectivity.
  • Self-healing safeguard
    Start with a genuine HP BIOS every time. HP Sure Start Gen3 monitors in-memory BIOS, recovers the platform without user or admin intervention, restores the BIOS to a custom state, and is enterprise ready for centralized management.
  • Super secure. Super protected
    Keep data out of reach and defend against theft, attacks, and unauthorized users with HP Client Security Suite Gen3.
  • Get PC images right the first time
    ITDMs can quickly help create, improve, and secure custom Windows images with HP Image Assistant.
  • Speed up the basics of IT management
    The HP Manageability Integration Kit helps speed up image creation and management of hardware, BIOS, and security through Microsoft SCCM.
  • Built-in durability
    Rest easy with a PC that goes the distance and is designed to pass HP Total Test Process and MIL-STD 810G testing.
HP EliteDesk 800 G3 - SFF Core i7 7700 3.6 GHz - vPro - 8 GB - SSD 256 GB - UK
Personal computer - SFF
Platform Technology
Intel vPro Platform
Intel Core i7 (7th Gen) 7700 / 3.6 GHz (up to 4.2 GHz, (Quad-Core)
Processor Socket
LGA1151 Socket
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2, Intel Smart Cache
Cache Memory
8 MB
Cache Per Processor
8 MB
RAM
8 GB (installed) / 64 GB (max) - DDR4 SDRAM - non-ECC - PC4-19200
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
SSD 256 GB - PCI Express 3.0 x4 - M.2 2280 - NVM Express (NVMe), triple-level cell (TLC)
Optical Storage
DVD-Writer
Graphics Controller
Intel HD Graphics 630
Audio Output
Stereo
1GbE
Keyboard
OS Provided
Windows 10 Pro 64-bit Edition
38.8 cm x 30.8 cm x 10 cm
5.31 kg
Manufacturer Selling Program
HP Smart Buy
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years - on-site
Platform Technology
Intel vPro Platform
Personal computer
Product Form Factor
SFF
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Clock Speed
3.6 GHz
Max Turbo Speed
4.2 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA1151 Socket
Chipset Type
Intel Q270
Cache Memory
Installed Size
8 MB
Cache Per Processor
8 MB
RAM
Installed Size
Effective Memory Speed
2400 MHz
Rated Memory Speed
2400 MHz
Memory Specification Compliance
PC4-19200
DIMM 288-pin
Slots
4 (Total) / 3 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
1 x 8 GB
Hard Drive
SSD - M.2 2280
1 x 256 GB
Interface Type
PCI Express 3.0 x4
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
DVD-Writer - SATA
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
VGA, DisplayPort
HDCP Compatible
Max Monitors Supported
3
Audio Output
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP Business Slim Keyboard
USB
Localization & Layout
Mouse
Optical
USB
Ethernet Controller
Intel I219-LM
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3az
Bays
1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 1 (free) x external , 1 (total) / 1 (free) x internal 2.5" x 1/8H , 2 (total) / 2 (free) x internal 3.5" x 1/3H
Slots
1 (total) / 1 (free) x M.2 Card - 2230 (x1 mode) , 1 (total) / 0 (free) x M.2 Card - 2280 (x4 mode) , 2 (total) / 2 (free) x PCIe 3.0 x1 - low-profile , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile (x4 mode) , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile
4 x USB 2.0 (2 front, 2 rear) (two of them with wake functionality) , 6 x USB 3.1 Gen 1 (2 front, 4 rear) (one of them is fast-charging) , 1 x USB-C 3.1 Gen 1 (1 in front) (charging) , 2 x DisplayPort , 1 x VGA , 1 x headphones/microphone (1 in front) , 2 x audio line-out , 1 x audio line-in , 1 x LAN (Gigabit Ethernet)
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
ACPI, CCC, CECP, SEPA
HP Smart Buy
Power supply
Power Provided
180 watt
80 PLUS Certification
80 PLUS Platinum
Efficiency
90% at 20% Load (115 VAC), 92% at 50% Load (115 VAC), 89% at 100% Load (115 VAC), 91% at 20% Load (230 VAC), 93% at 50% Load (230 VAC), 90% at 100% Load (230 VAC)
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition English
Sustainability Information
ENERGY STAR Certified
38.8 cm
30.8 cm
10 cm
5.31 kg
10 °C
35 °C
10 - 90% (non-condensing)
Warranties (7)
CT9V HP 3 Year NBD On-Site Optional Customer Self Repair Desktop/Workstation Only Hardware Service In Stock £33.64
CT9V HP Care Pack Next Business Day HW Support Post Warranty Extended Service Agreement 1 Year On-Site In Stock £26.43
CT9V HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site In Stock £34.84
CT9V HP Care Pack NBD Hardware Support with Disk Retention Extended Service Agreement 3 Years On-Site In Stock £70.87
CT9V HP Care Pack NBD HW Support w/ Defective Media Retention Extended Service Agreement 4 Years On-Site In Stock £58.87
CT9V HP Care Pack NBD Hardware Support with Disk Retention Extended Service Agreement 5 Years On-Site In Stock £81.69
CT9V HP Care Pack Next Business Day HW Support Extended Service Agreement 4 Year On-Site - Desktop Only In Stock £28.01
Other bundles (5)
CT9V HPE DisplayPort DVI-D Adapter In Stock £19.88
CT9V HPE DisplayPort to VGA Adapter In Stock £13.22
CT9V HPE USB to Serial Port Adapter In Stock £13.95
CT9V HP USB-C To VGA Adapter In Stock £23.07
CT9V HP USB-C to HDMI 2.0 Adapter In Stock £47.48
