Business demands confidence. Here's yours. Designed to perform, impress, and protect-the sleek HP EliteDesk 800 G1 helps you power through to business success while allowing customized deployment.
The solution for diverse business demands
The new way to do business. Impress and perform like never before-and meet a variety of business demands-with highly customizable tools, new features and a stylish new design.Easily share your internet connection with your devices and help colleagues get online fast with HP Wireless Hotspot.Share presentations, videos, and other content-no cables needed. WiDi Intel Wireless Display lets you connect your EliteDesk to your projectors and displays wirelessly.The new, slim removable hard drive lets you secure your most important data when you're away from the office. The optional PCI port helps ensure broad compatibility with existing technology investments. -
Fast-track your performance
Multitask and move your business forward with the latest Intel processors. Quickly open new files, switch applications, and enjoy less wait time with solid-state drives and solid-state hybrid drive options.Power through your day with speed and performance. Get the latest in processing technology with your choice of 4th generation Intel Core processors with vPro support.Watch your inbox while working on other tasks. There's plenty of screen room for all of your work with support for multiple displays.Intel Smart Response Technology (SRT), a disk cache solution, delivers similar performance associated with Solid State Drives while retaining the data storage capacity of today's large Hard Disk Drives.Make the most of virtual conferencing. Bring work to life through immersive surround sound with deep, rich bass and crystal clear dialog using DTS Studio Sound software. -
Heavy security, exceptionally managed
Keep it secure, keep it simple. IT efficiency reigns supreme when it's backed by a full portfolio of HP Client Security and Intel vPro management features.No more remembering passwords. HP Password Manager lets you quickly log in to various online accounts. Now your passwords can be longer and more secure.Save your data. RAID configurations utilize dual storage drives to automatically back up and help protect your sensitive data.Stay up and running. HP BIOS Protection offers enhanced protection against virus attacks and other security threats, and is designed to help prevent data loss and reduce downtime. -
Reliability for the long haul
Count on the support you need to get long-term value out of your investment. This work-ready PC is designed for a long lifecycle, with platform stability up to 30 months.Rest assured. Talk to an agent any time and get priority service at any HP repair center with HP Elite Premium Support, at no additional charge.HP EliteDesk PCs are rigorously tested to help ensure reliability. During the HP Total Test Process, our PCs experience 115,000 hours of performance trials to help get you through your business day.
- HP EliteDesk 800 G1 - ultra-slim desktop - Core i3 4160 3.6 GHz - 4 GB - HDD 500 GB - TAA Compliant
- Personal computer - ultra-slim desktop - administrator password, power-on password, USB port control, HP Disk Sanitizer, Intel Active Management Technology (iAMT), Intel Identity Protection Technology (Intel IPT), Setup Password
- Localisation
- Processor
- Intel Core i3 (4th Gen) 4160 / 3.6 GHz (Dual-Core)
- Cache Memory
- 3 MB
- Cache Per Processor
- 3 MB
- RAM
- 4 GB (installed) / 16 GB (max) - DDR3 SDRAM - non-ECC - PC3-12800
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- HDD 500 GB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- DVD SuperMulti
- Graphics Controller
- Intel HD Graphics 4400 Dynamic Video Memory Technology
- Audio Output
- Stereo - integrated
- Networking
- 1GbE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 8.1 Pro) + Windows 8.1 Pro Licence
- Software Included
- Cyberlink PowerDVD, CyberLink Power2Go, Adobe Flash Player, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP Support Assistant, Bing Toolbar, HP ePrint, Foxit PhantomPDF Express, Microsoft Internet Explorer 10, Device Access Manager, HP Client Security, HP PageLift, HP File Sanitizer, Box, Drive Encryption, HP Disk Sanitizer External Edition (free download)
- 25.1 cm x 25.4 cm x 6.6 cm
- 3.1 kg
- TAA Compliant
- Limited warranty - parts and labour - 3 years - on-site
- Personal computer
- Product Form Factor
- Ultra-slim desktop
- Built-in Devices
- Solenoid hood lock
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 3.6 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- Chipset Type
- Intel Q87
Cache Memory
- Installed Size
- 3 MB
- 3 MB
RAM
- Installed Size
- 4 GB / 16 GB (max)
- Technology
- Effective Memory Speed
- 1600 MHz
- Rated Memory Speed
- 1600 MHz
- Memory Specification Compliance
- PC3-12800
- Form Factor
- SO-DIMM 204-pin
- Slots
- 2 (Total) / 1 (empty)
- Unbuffered, dual channel memory architecture
- Configuration Features
- 1 x 4 GB
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA - integrated
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Video Interfaces
- VGA, DisplayPort
- HDCP Compatible
- Max Monitors Supported
- 3
Audio Output
- Integrated
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 192 kHz
- High Definition Audio, DTS Studio Sound
Input Device
- Mouse, keyboard
Keyboard
- Interface
- USB
Mouse
- Interface
- USB
- Integrated
- Ethernet Controller
- Intel I217-LM
- Data Link Protocol
- Remote Management Protocol
- ASF 2.0
- Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
- IEEE 802.2, IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3az
- Bays
- 1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 0 (free) x internal 2.5"
- Slots
- 2 (total) / 1 (free) x SO-DIMM 204-pin , 1 (total) / 1 (free) x mSATA , 1 (total) / 1 (free) x PCIe Mini Card , 1 (total) / 1 (free) x MXM , 1 (total) / 0 (free) x CPU
- 6 x USB 2.0 (2 front, 4 rear) , 4 x USB 3.0 (2 front, 2 rear) , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x VGA , 2 x DisplayPort , 1 x headphones (1 in front) , 1 x microphone (1 in front) , 1 x audio line-in , 1 x audio line-out , 1 x LAN (Gigabit Ethernet)
- Administrator password, power-on password, USB port control, HP Disk Sanitizer, Intel Active Management Technology (iAMT), Intel Identity Protection Technology (Intel IPT), Setup Password
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- ACPI, RoHS, WEEE
- TAA Compliant
- Power adapter
- Voltage Required
- Power Provided
- 135 Watt
- Efficiency
- 87%
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro) + Windows 8.1 Pro Licence
- OS Certified
- SUSE Linux Enterprise Desktop 11
- Software
- 25.1 cm
- 25.4 cm
- 6.6 cm
- 3.1 kg
- 10 °C
- 35 °C
- 10 - 90% (non-condensing)
